Results 1 to 10 of 14
05-08-2012, 08:43 PM #1Junior Member
- Jun 2011
- 14
Cable rack to Hydraulic steering conversion
So I was looking into a hydraulic steering system for my 08 Supra Launch to reduce the slop in the rack style steering as well to improve the 2 hand turning method when the sacks have 2200 lbs of ballast in the boat. Yes I said Supra, but Supra/Moomba, Same manufacture so same improvement. I looked all over the Internet to try to find some sort of information about this conversion and after checking every wakeboard boat manufacture forums I came up with nothing. So I started my research and found a solution.
Items needed.
-Seastar sport helm pump. Before you go and buy all of this gear make sure you have the Seastar SPORT tilt helm. The seastar SPORT tilt helm is what comes on moomba/supra from the factory but with a cable rack behind it, however there may be some oddballs out there. As for the helm pump, You need the pump with the flat!!! adapter shaft. (see pictures) The taper/Splined ones do not come with the proper mounting holes and shaft and will not work with your sport tilt helm. Finding the pump alone without the tilt helm is a bit of a challenge but I managed to find one on Ebay for 270 brand new, shipped to my door.
-Hydraulic ram. I got a Seastar BA135x7-BJ. It has a 7" stroke which is the same as the cable steering on the boat. I found it on ebay for 80 bucks recently rebuilt and shipped.
-Seastar hydraulic lines. You will need 2 of them. My boat is 21 ft long and 20 foot ones worked perfect with extra to spare. Better be long than short, you can always coil them up with no worries unlike a cable setup.
-The last item you need is a bracket to mount the ram. I made one out of 1/4" steel cut and welded into shape. I would have preferred aluminum or stainless but the steel was at my disposal. It is essentially 2 6"x6" pieces of steel with the holes drilled in them welded at the correct angle for the ram.
-Some stainless hardware found at home depot.
Once you have all of the parts needed, you can start the process.
Remove the old steering cable making sure to tie a rope to the end so you have something to feed the hydraulic lines through. Remove the steering cable mounting plate bolted to the bottom of you hull by the same bolts that hold your strut on. Take the 2 pieces of steel and drill holes in them that match the ram and the mounting bolts on the bottom of the hull. Due to the fact that the ram is longer than the cable setup, I had to switch the 2 aft (longer) bolts with the forward (short) to accommodate the longer ram. MY strut has 6 bolts total. Note the picture attached on which bolts I used. After mocking up the ram and the pieces of steel, tack them together and make sure you have full travel on your steering. After verifying everything is in the correct place and angle weld it up solid and preserve the crap out of it. I powder coated mine to try to make it last. After getting the ram mounted, the hard part is over.
The helm is fairly straight forward and requires little fab work. You have to start by removing the 20 degree shim to allow the much bigger helm pump to clear behind the wheel. You can see in the attached pictures the helm mounted without the shim. Once removed and bolted back up, trim the bolts to allow the helm pump to mount up. Bolt it up with the same bolts used to hold the cable rack in place and put your steering wheel back together.
Plum the lines to the helm pump and the cylinder. BEFORE YOU TAKE THE BOAT FOR A TEST SPIN, ENSURE THE RUDDER TURNS THE CORRECT DIRECTION. If it doesn't, it is as simple as switching the lines on the helm pump. Once everything is plumbed up and all of the lines are zip tied securely, Bleed the system per the seastar instructions. If you want to spend 20 bucks a quart (you need 2) on seastar hydraulic fluid, by all means do so... After working on a farm for years I have realized that dexron/mercon 3 does the same job at a 1/4 the price. It works great on my setup.
Once everything is bled and ready to go, Enjoy a beer and take the boat for a spin and be amazed at how much improvement this is. I filled the sacs up and was able to turn the boat on a dime with one hand with barley any force. Absolutely no play in the steering as well when planed out.
The whole setup cost me around 400 bucks minus the beer and about 6 hours to fab up. THE best 400 bucks I have spent on this boat.1999 Outback Please someone buy her.
2008 Supra launch 20ssv
05-08-2012, 08:50 PM #2Junior Member
- Jun 2011
- 14
Here are some more pictures of the install.Attachment 14226Attachment 14227Attachment 14224Attachment 14225
05-09-2012, 07:07 PM #3
if i had 400 i would drop this in my outback
Rockford fasgate cabins
Exile XM7's
Exile Harpoon
Polk 10in sub (2)
Polk P330 amp (subs)
05-09-2012, 07:42 PM #4
that's a very impressive DIY, job well done sir
Sent from my home phone..Jason
2009 Moomba Mobius LSV
05-10-2012, 02:19 PM #5
Nice work. So I'm curious how much tension you have in the wheel. When you're not loaded down is it fingertip steering at any speeds? How about when you are up to speed and running straight - can you let go of the wheel without the boat wanting to start into a turn on it's own?
05-14-2012, 05:45 PM #6
That's what I was wondering. I don't mind a little tension on the wheel I find that I don't wonder so much when pulling someone.
-Mark
"Hey you only live once"
08-15-2012, 07:44 AM #7Junior Member
- Jun 2011
- 14
Well 6 months later over 150 hours on the steering and it is working as well as day one. Absolutly no slop in the steering. With the boat planed out doing 30, I can let go of the wheel and it goes straight till I grab the wheel again. One finger operation when planed out, however with 3000lbs of ballast you have to grab the wheel but one hand only.
08-15-2012, 11:33 AM #8
So glad this worked out. I have a little play in mine now. Time to tighten everything up.
08-16-2012, 08:29 AM #9
I'm assuming that the helm pump is a self contained pump and orbital valve? Sweet looking setup certainly beats worrying about steering cables
2005 mobius lsv 2900lbs ballast2005 mobius lsv
08-17-2012, 08:38 PM #10Junior Member
- Jun 2011
- 14
Yes, the Helm is essentialy a rotory vane pump coupled to the steering wheel. You can get different sizes of helms or cylinders to increase or decrease the number of wheel turns side to side. The smaller the pump the more the turns as well as a larger ram will increase the number of turns. My setup gave me around 4.5 turns side to side which was about the same as the stock cable.
