Results 1 to 2 of 2
Thread: First Day Trouble
05-06-2012, 11:05 PM #1
First Day Trouble
I took the boat out for the first time and wanted to do some surfing but the bags would not fill. The pumps would not run to fill but they would run to drain the bags. I need help to figure out what is wrong. It is a 04 LSV with GIII factory setup.
04 LSV
05-06-2012, 11:27 PM #2
Check fuses, id assume your using areator pumps?
Make sure the fill pump is comming on, when you hit the fill switch it turns that pump on plus activates the valve on the tree to select the bag you want to fill.
If you get nothing at the pump you can run extra wire over to it from the battery, jump the pump, this will tell you if the pump its self has gone bad.
If the pump comes on but the valve isnt opening then you can replace the valve from Home Depot about 10 bucks.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
