Results 1 to 7 of 7
Thread: Prop help!!
05-05-2012, 01:35 PM #1
Prop help!!
I can't get the prop off my boat.. got the cotter key out, got the nut off, put prop puller on, tightened the #$%# out if it, hit it with a hammer from behind.. nothing... any ideas?
08 Outback. Private Lake Owner.
05-05-2012, 01:48 PM #2
Heat it with a propane torch.
-2012 Supra Launch 21V
-2008 Mobius LSV
05-05-2012, 02:05 PM #3
05-05-2012, 03:28 PM #4
+3...put the prop nut back on and heat it up just a little. NEVER take the nut off prior to the prop popping loose. It's probably a blessing that you're having issues because IF the prop popped loose without the nut you could have injured yourself (don't laugh...there's a good chance you would have) and/or you would have dinged the prop when it hit the ground because there's no nut to stop it from flying off the shaft.
05-05-2012, 03:29 PM #5
I got it off.. thanks... I just cranked on it like a b***! Boat runs awesome now.
05-06-2012, 09:11 PM #6Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
What was the cause / solution to the boat running issues?
07 Outback DD
05-06-2012, 09:13 PM #7Senior Member
- Jun 2007
- 926
Sorry hadn't got to the other thread yet...
07 Outback DD
