Results 1 to 3 of 3
05-04-2012, 11:03 AM #1
GIII Timer setting for 2011+ models
I got the below from SC. This works for those with Digital Cruise Pro (the one with the screen). If you have the Digital Cruise (the one with just the buttons), you're may have some luck with your dealer resetting, but it sounds like it will be difficult.
How to set timers for Digital Cruise Pro on 2011+ SC boat models:
Turn on key. Main Screen should come on after splash screen.
Hold down “Menu” button for 2 seconds.
Hit “up” arrow to highlight “BLST”
Hit “Menu” to enter Ballast set up screen
Hit “up” arrow to highlight “Set timers”
Hit “Menu” to enter set timers screen
Hit “up” or “down” arrow to change time for each bag.
Hit “Menu” to go to next bag.
Hit “On/Off” when all timers are set correctly
Hit “On/Off” again to go back to screen selection options
Hit “On/Off” again to return to main screen
05-04-2012, 01:17 PM #2
Does this apply for zero off as well.
Thanks Drew for this update, did not want to do the Mario brothers unlimited life sequences on the ballast.
Sent from my ADR6300 using TapatalkA Day at the Lake...Priceless
05-04-2012, 02:11 PM #3
Yes, this works for the zero off system as well. The only difference between Zero off and Digital Cruise Pro is that Zero Off has a GPS antenna it reads speed from.
