Results 1 to 10 of 11
    Apr 2012
    Wake Forest, NC
    Default Couldn't keep thru-hull from turning
    I've been working on my ballast install today and I'm almost done but ran into a problem when tightening the thru hull nut. I had a buddy stick a prybar into the hole from the bottom to try and keep it from turning but you can't get any leverage. Anyways it's pulled flush with the hull and I used the marine sealant on the top and bottom, and there is no play in the fitting. Think I'm alright? Thanks
    2008 Outback V
    If it has the little tabs or bars on the inside of the fitting you may be able to use this trick.
    Put a wrench on the flat edge of the handle for more leverage. I used this breaker bar handle on both my bottom (underwater) thru hull and above water thru hulls on the sides.
    It's not a high pressure system so as long as you have some sealant under the fitting you are probably good. For a below the water connection I would definitely spend a little extra effort to get it as tight as possible though.
    Oct 2010
    Lake Wylie NC Area
    Z,
    What you are experience is not uncommon. The marine adhesive makes for a great lubricant while in its uncured state. So even with the jam nut tight, the thin barrier of sealant can allow the t-hull to rotate. let it cure and you should be fine. Also, I would go ahead and put on the ball-valve while you are at the point you are at. This way, if you need to rotate the whole setup to get the ball-valve handle oriented so it has the clearance to be shut off, you can rotate the assembly.
    Sep 2010
    Lake wallenpaupack PA
    Quote Originally Posted by z28ke View Post
    Since its under the water line i would make sure its tighter than a whales a$$
    Aug 2011
    Quote Originally Posted by lsvboombox View Post
    Don't want to over tighten, crack the gel coat/spider cracks... The sealant is what makes it water tight...
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Sep 2010
    Quote Originally Posted by parrothd View Post
    Agreed. A whales sphincter does not spin and isnt cracked.
    And if anyone wants to see a whale weiner i got a picture
    Belton, Texas
    Think we'll all pass on the whale Werner pic, well maybe Chawk wouldn't mind a quick peak-
    2009 Moomba Mobius LSV
    Apr 2012
    Wake Forest, NC
    Haha, no thanks. I let the sealant dry good before I put on the ball valve and kept an eye on the nut to make sure it wasn't turning as I tightened the valve. It held tight so I think it's good to go. I'll check it on the water before I back off the trailer. Thanks for all the help guys, I couldn't have done this project without all the good people and threads on this board! I can't wait to get on the lake sunday and try it out, throwing pumps over the side of the boat is for the birds
    2008 Outback V
    There's about 10 Dusty's Mom-isms in the description above.
    It's also for folks with boats that have hard tanks and need more weight but don't want to drill holes, add pumps, etc.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
