Results 1 to 10 of 53
Thread: Outback.. kinda slow.
04-23-2012, 12:49 PM #1
So I have an outback, and did a WOT test yesterday, with nearly empty fuel tank, and 4 people, stock OJ 13x13 prop. 3 blade. Wot was 38 mph on the speedo (forgot to check PP) and 5050 on the rpm's. Shouldn't I be getting to about 5200/5300 on rpm? Also thought top end should be about 44 mph.
08 Outback. Private Lake Owner.
04-23-2012, 12:59 PM #2
Did you GPS check it? Could be your speedo is a little off. Also when I went from the stock 13.7x17x5 prop to a 14.25x14.5 on my mobius I gained a little on the top end because with the stock prop at WOT i could only get to 4500 rpm max. With the wakeboard prop it would actually get to max rpm at WOT.
-2012 Supra Launch 21V
-2008 Mobius LSV
04-23-2012, 07:44 PM #3
usa - Your max boat speed should be in the 40s. If memory serves me correct, last season my '07 Outback at WOT hit 45 mph, running w/ factory propeller. - Deerfield
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
04-23-2012, 07:54 PM #409 21v LAUNCH
99 Outback LS. Sold
Doug
04-23-2012, 09:06 PM #5Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
I agree with Deerfield, stock prop and WOT should be just under 5000 rpm and around 44,45 mph.
07 Outback DD
04-23-2012, 09:14 PM #6
04-23-2012, 10:43 PM #7
going to have to do some more tests with the stargazer gps. I think with it off, it will tell you the speed.
04-24-2012, 08:53 AM #8Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Owners manual for your boat states 4400-4800 WOT range if you have the 325 hp motor.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
04-24-2012, 12:39 PM #9
Strange, if 4800 is max WOT, why would the rev limiter be set higher? I know I saw 5050 on the digital tach (perfect pass)
04-24-2012, 03:16 PM #10Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Found my Perfect pass to be a little tight and WOT was not really WOT. Although, your RPMs sound about right.
SD2Naked red and white 2005 Moomba LSV
