Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Jul 2009
    Fort Worth, TX
    The Kicker requires 8ga power and ground wires, the Rockford requires 4ga. Not sure what size power wire you would want to use from the battery/battery switch but I would think 2ga is big enough.. Something like this should get the job done. http://www.sonicelectronix.com/item_...er-SHD820.html
    -2012 Supra Launch 21V
    -2008 Mobius LSV
  2. #22
    Oct 2010
    Lake Wylie NC Area
    Quote Originally Posted by Cigars n scotch View Post
    Ah, I have two.
    Kicker zx200.4
    Rockford Fosgate p500-2
    CnS,
    How many speakers do you have on the zx200.4 and is the p500/2?
    Also, what is the distance from the battery to where you intend to mount a distro block?
    Depending on a couple of factors, you have some options. You have trunk line and a main point of circuit protection right off the battery, then use a pair of non-fused blocks close to the amps to split off. Or, come right off the battery with a fused distrobution block, like what is linked above, the use a single non-fused block on the GND side. Or, use a fused/GND combo block.
  3. #23
    Mar 2012
    South Carolina
    Thanks. It says it requires 2 midi style fuses. What amperage do I get? I have 100amp fuses on the RF AMP.
  4. #24
    Mar 2012
    South Carolina
    Goodness MLA, you're speaking Chinese to me!
    On the kicker I have 6 in cabins, and for the Rockford I have 2 WS Pro80s.
    The battery is no more than a foot away.
    Here's a picture of my observers seat compartment where everything is. The inside wall to the right of the battery is where the switch and distro block would go
  5. #25
    Jul 2009
    Fort Worth, TX
    I believe you would get whatever size fuse the amplifier requires. That information should be in the manual for the amp.
    -2008 Mobius LSV
