Results 1 to 8 of 8
    Houston, TX
    Default Sheilded Wire for Remotes
    I have two of the AEWARE remotes which work great with my head unit. The problem I have is at high volumes the current from the speaker wires interferes with the remotes causing them not to function. I was wondering if running a shielded wire for the remotes would eliminate this problem. Anyone have any knowledge / experience? Anything helps.
    Houston, TX
    Bump - Anyone else have this issue?
    Feb 2008
    Traverse City, MI
    Thats a strange one. I don't have AEWare remotes, but I have 2 Kenwood remotes and have never experienced this issue. Are you sure its not something else causing the problem? To test I would run a separate signal wire from the remote to the headunit and crank it up, if it still happens ditch the AEWare and get Kenwood.
    2013 Outback V
    Feb 2010
    Canton, Ga / Lake Lanier
    I agree. I had those Aeware remotes in my last boat and had the same problem. In my new boat I have Kenwood remotes no problems here. However they are the digital remotes and not the regular ones. But I really think those Aeware remotes are just bad. I think the standard Kenwood remotes would be better. You can usually find them for $50 or less...
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Houston, TX
    Same problem where the remote stops working at high volumes?
    I would just buy 2x 107MRs but I would also have to switch headunits as I have the Kenwood KDC-X493 (car unit from previous owner). It works great with the iPod where I can change tracks from the AEWARE and it has 4V pre-outs. I just need to fix this one issue at high volume. Seems like a cheap fix if shielded wire could be the solution.
    Feb 2010
    It wasn't necessarily at high volumes they would just randomly stop working. It was REALLY annoying. The 107 remotes are GREAT! I got them and the radio off eBay for pretty good deals.
    I would definitely try your shielded wire idea and see if it would work...
    Tow Rig:
    Feb 2008
    Traverse City, MI
    Replace the AEWare with KACRC60MR - it should be a direct replacement. I am using 2 of those, and a 107MR, and all work perfectly.
    2013 Outback V
    Apr 2008
    California
    I had two Aewares for two seasons and never experienced any issues what so ever with them. When I installed the transom unit I used simple 4 strand unshielded 22ga security wire. Sold them to another member on here and they're still functioning just fine as far as I know.
