Results 1 to 3 of 3
Thread: 05 lsv radio?
    Jul 2011
    Rockwood,TN
    Default 05 lsv radio?
    I have a 05 lsv and when i turn my radio up if i go to loud it shuts off then comes right back on if i turn it down a little its fine if i leave it it just keeps doing this. Any suggestions?
    Oct 2005
    Durham, NC
    My boat use to do this, and sometimes still does. For me it was a battery issue. The stereo would drain the battery where the voltage or amperage would drop below the minimum level, and the head unit would shut off. As soon as it did, the voltage/amperage would jump back up, and the unit would come back on. I ended up adding a second battery, and it still did it. I found out that with my weak 55 amp alternator, I have to charge my stereo battery between trips to the lake or it will still do it.
    If you don't have a crazy stereo system, and this a recent problem, your battery may be dying.
    Jul 2011
    Rockwood,TN
    I've only had the boat since June of last year and it has done it since i bought it. I thought the same thing maybe its the battery put two new optima blue tops in it and it still does it. It already had the dual battery set up when i got it. I'm gonna try to charge both batteries on a trickle charge before i go out may work i hope. Thanks
