Results 1 to 10 of 13
Thread: Dual Battery Installation
04-11-2012, 05:30 PM #1
How easy is it to install another battery. I always forget to turn on some switch and it runs it down. I know I need one of these http://www.overtons.com/modperl/prod...C&merchID=4006 and a battery, but is there another else. If anyone has pictures of what I need or how to do it that would be awesome.
2016 Mojo
2010 Moomba LSV-Sold
04-11-2012, 05:34 PM #2
I bought my perko switch and battery an then took boat to local stereo shop and had them install it. Think tower speakers, along with second battery and perko labor was about 140.00. I know this don't answer your DIY question but the 140 was easier than getting a few more grey hairs
Sent from my iPhone using TapatalkJason
2009 Moomba Mobius LSV
04-12-2012, 09:30 AM #3
I think I found this one or one like it for about $35 by searching the net:
http://www.amazon.com/Perko-8511DP-C.../dp/B001BOPBTY
Easy to install yourself and comes with directions based on the set up you want. I put everything from the positive terminal on the switch so depending on which battery I'm running everything works. Others like to run a separate battery for the stereo. I just wanted a second battery in case I run dead so I can just switch over. I keep them both charged and ready but you never know.
The biggest difficulty with the install is removing your battery cable connector from the end of the long cable that goes back to the starter. You have to remove the cable connector and install a ring connector so it will go on the terminal on the new switch. I found a part at Home Depot to do this job. Otherwise you have to crimp or solder (or both) the new connector on there. (BTW, there was a huge debate not long ago on what the best way to make this connection is.) Good luck! Oh yeah, I would go to the Perko site and see if you can get the .pdf of the directions. Might make it easier for you.My Mom said I'm not allowed to get wet!
04-12-2012, 09:34 AM #4
This is the one I installed:
http://www.amazon.com/gp/product/B00...d_i=B001BOPBTY
I was able to just twist the cable end right off the cable and add a ring connector attached with a compression end. The one I used looked a lot like this:
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051My Mom said I'm not allowed to get wet!
04-12-2012, 10:45 AM #5
It might be worth it to get one with an alternator field disconnect (AFD) so that if someone turns the switch to off while the engine is running it doesn't damage your alternator. I just got the standard switch because it was out of the way and I knew no one was going to mess with it, but it's something you may want if you think someone might mess with it.
-2012 Supra Launch 21V
-2008 Mobius LSV
04-12-2012, 07:06 PM #6
04-12-2012, 08:15 PM #7
04-13-2012, 10:59 AM #8Senior Member
- Aug 2011
- 2,522
I use an Isolator, much easier than the perko switches...When the boat is running it charges both batteries, when off the batteries are isolated from each other, you run all your accessories, radio, pumps, etc,etc off the second battery the primary battery is only used for starting....
http://www.amazon.com/Inboard-Batter.../dp/B002JQ9UL8Last edited by parrothd; 04-13-2012 at 11:02 AM.
04-14-2012, 03:52 PM #9
04-15-2012, 06:29 PM #10
