Results 1 to 3 of 3
04-06-2012, 04:20 AM #1
Help needed to track some gel coat,
After an un eventful 4hr drive to the loch where the boat lives for the season I pulled in to the boat yard only to put the tow hitch of a PWC!!! ( Hate) In to the side of the boat Chipping the gel coat.
I need to get a small amount of red Gel coat, ½ litter would be loads, But the UK’s so called dealer is rubbish.
Can I order this direct from Moomba and can it be shipped to the UK.
Any help or info would be much appreciated
Thanks Coley2008 Mobius LSV, Gravity III , Wake Plate, FI, Full Kicker sound set, Running on LPG, In England
04-06-2012, 07:32 AM #2
Send Skiers an email with your hull ID number (located on the transom, port side) and see if they can hook you up.
04-06-2012, 01:15 PM #3
Call spectrum with you HID#. Thats where skiers choice gets it. Its fairly inexpensive and easy to use.
http://www.spectrumcolor.com/Index.aspx?key=cat
PWI as usual...
