Results 1 to 3 of 3
Thread: Summerization process
04-02-2012, 05:12 PM #1
This is a reposting found in the How to Section for all the newbies to help them with a smoother first outing this year
SUMMERIZATION PROCESS
1. Install boat drain plug
2. Check platform bracket screws for tightness
3. Reattach all disconnected hoses from winter if not done. Raw water
strainer, v drive ,impeller housing, J tube, exhaust mani coupling.
4. Reinstall motor drain plugs and knock sensors, v drive drain bolts, tranny
cooler bolt, impeller and cover, and muffler drain bolt, if not done.
5. Clean battery terminals and connectors and install.
6. Check alignment of prop shaft coupler to v drive or tranny coupler. “Best to do in
water”
7. Check fluid levels of motor oil, tranny oil ,v drive oil and top up if
necessary.
8. Check grease in trailer bearings , brake fluid in reservoir, tire air pressure , and electrical.
9. Remove bag from flame arrestor if placed.
10. Turn key to power fuel pump.
11. Start motor and let any fogging oil burn off. Check for water leaks, and
oil leaks around oil filter from winterizing oil change.
12. Change and gap new spark plugs.
13. Replace fuel filter.
14. Reinstall speedo pick ups on mdc unit under dash if equipped.
Have a Beer for me
This is not meant to be a comprehensive list, just what I do or have done on my boats. Personally after winterization I perform 3 and 4 which makes the spring process less time consuming.
09 21v LAUNCH
99 Outback LS. Sold
Doug
04-02-2012, 10:23 PM #2
Doc you almost have to be a certified marine mechanic with 4 years of school to be able to do all that!! I need to take some on-line courses I guess wow
2009 Moomba Mobius LSV
04-03-2012, 08:55 AM #3
I'm just going to start with the one at the very end of the list next to the smiley.
