Thread: Heater Y pipe
    Jul 2011
    Murrieta, CA
    Default Heater Y pipe
    I saw that a heater Y pipe helps to keep the heater temp up while idling. I have a factory installed heater but it cools off quickly while idling.
    Where does the Y pipe get installed and what does it connect to?
    Thanks!
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    I believe it's between the raw water intake and the impeller housing.
    Couple pics in here. I never installed mine because it was too hard to get to at the time.
    https://forum.moomba.com/showthread....Heater+install
    Sep 2010
    Lake wallenpaupack PA
    I found it easiest to remove the water pick up hose between the vdrive and the impeller and install the wye outside the boat then slide it back in. I got a lsv and it was tight to install, skinned the knuckles then decided to pull the hose.
    Jul 2011
    Murrieta, CA
    I think I just figured out how it works.
    Am I correct that the Y on the intake line acts as the suction to pull the heat through the heater core? The hot water is still coming from the block.
    I was thinking backwards earlier and wondering how the cold sea water would hear anything.
    Thanks for the insight.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
    Sep 2010
    Quote Originally Posted by Boonejeepin View Post
    Yep..............
