Results 1 to 3 of 3
Thread: Speed odometer inop
03-28-2012, 10:19 PM #1Junior Member
- Mar 2012
- 8
Speed odometer inop
I have a 2003 moomba outback Lsv my speed odometer is not working any ideas where I can start? I have of wheel or something on hull that can be cleaned .
2003 Black Outback LSV
350 EFI
GRAV III BALLAST
03-29-2012, 01:30 AM #2
If you have checked the wheel on the hull of your boat and it looks fine, then test the wiring, something may have been damaged or disconnected.
2004 Moomba LSV Blue
03-29-2012, 07:27 AM #3Member
- May 2010
- North Dallas, TX
- 81
I am currently going through the same problem. I thought it was the paddle wheel and bought Nautic Laugic GPS and that didn't fix it. I have since checked the wiring and that is what has gone bad. I am going to change out the connectors and I hope that fixes it. If not I will have to pull the whole wire going from the dash to the paddle wheel. At least I'll have gps when it's all said and done and hopefully it works.
