Results 1 to 10 of 11
Thread: I hear a whistle noise!
03-28-2012, 08:41 AM #1Junior Member
- Mar 2012
- Gadsden, AL
- 6
When I put my boat in gear and Idel around I can hear a whistle type sound it goes away the more I speed up.. I had prop redone i don't know I don't know if it's that as the prop spins against the water... It does not do this in reverse... Maybe it's something I've never noticed in the past.. Anyone have a idea of what it might be? I have a 07 Moomba Möbius LSV
03-28-2012, 10:33 AM #2
I had a whistle noise at low speeds when running the OJ wakeboard prop. Switched to the Acme 1433 and the whistle and a lot of growling went away.
03-28-2012, 11:46 AM #3
It can also be from the air being sucked thru the throttle body and flame arrestor. Check this area for the noise to rule it as or out.
09 21v LAUNCH
99 Outback LS. Sold
Doug
03-28-2012, 03:58 PM #4
I had that problem once. Turned out it was how I had my head turned, it was the wind whistling through the empty noggin... sad but true...
Kraig - 2010 Outback V
03-28-2012, 05:26 PM #5
Are you sure Andy Griffith wasn't playing in the background.
PWI as usual...
03-28-2012, 07:50 PM #6
03-28-2012, 09:53 PM #7
Well, golllll --- ollllllll---eeeeeeee.
03-29-2012, 07:34 AM #8Junior Member
- Mar 2012
- Gadsden, AL
- 6
It must have been your Bayliner Ksmith I don't know what the issue would be!
07 Moomba Möbius LSV, Bright Orange , 20" Rockstar Rims on trailer, 4 6.5 kicker High and 2 6.5 Kicker subs on tower, 6 6.5 Kicker high on bottom with a 10" Sub stereo will blow u outta water.
I don't buy my boat to ride in I buy my boat to go Big behind!
03-29-2012, 09:08 AM #9
03-29-2012, 03:27 PM #10
It's probably your wife trying to get your attention
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
