Results 1 to 6 of 6
    Jul 2011
    Central Wisconsin
    Default Overheat buzzer on our boat?
    Anyone know if our 2000 Moomba Mobius V would have an overheat buzzer? Thanks!
    -Ryan
    twitter.com/WakeVideos
    2000 Mobius V
    Feb 2008
    Traverse City, MI
    I don't, but is something wrong with the gauge?
    2013 Outback V
    Jul 2011
    Central Wisconsin
    Nope, just asking out of curiosity. Gives you piece of mind if you know the boat will alert you if you aren't checking the temp gauge.
    -Ryan
    2000 Mobius V
    Ha - good luck with that... With a fresh water system and low temp thermostat you aren't likely to get too hot. We don't get the warm water temps like they do in the south either. Unless you have blockage or failing pump/impellor you should be good to go. Just make it a point to glance over at your temp gauge every time you go to put it into gear.
    Jul 2011
    Central Wisconsin
    Exactly! That's why I was asking Putting the boat in the water in 2 weeks!
    -Ryan
    2000 Mobius V
    Jealous... Not even thinking of pulling the cover off for another 2 months.
