Results 21 to 30 of 41
    May 2012
    Birmingham, AL
    I'm trying to change my oil in my 05 moomba mobius lsv. It has the 5.7l carb motor I believe. How many quarts Does it call for???? I check my Manuel must have overlooked it.
    2005 Moomba Mobius LSV
    I believe it's 5 qts.
    May 2012
    Birmingham, AL
    Thanks. I'll start with 5 then check.
  4. #24
    Sep 2005
    Claytor Lake, VA
    5 qts including filter.
    2005 Mobius LSV
  5. #25
    Aug 2007
    Alpine, Utah
    If you go with synthetic, what weight would you use?
    Garn
    Garn
    2007 Mobius LS (Direct Drive)
  6. #26
    Default Note from Indmar - CHANGE YOUR OIL!
    Same weight at non synthetic 15w40
    Sent from my iPhone
  7. #27
    Jun 2015
    San Antonio, TX
    i have a 98 moomba outback. which oil and filter do you recommend?
  8. #28
    Sep 2015
    Wow, I've never heard of 5700 lbs of ballast. I am def. going to ask my buddy about this since he mc's a lot of the tour events. I just thought that was a typo or something.
    not to change the subject but isn't this well over the weight limit for the boat??
  9. #29
    May 2016
    Lake Mitchell, Alabama
    I think we will all see variances based on the activities we do and the weight we run. This test was done at extreme, competitive ballast weights. I don't know many that run, or need to run, that kind of weight for wakeboarding.
    What exactly are your competitive weight settings?
    2016 Craz
    1979 Ski Nautique
  10. #30
    Jun 2014
    What kind of oil does everyone use? Im using SAE 15W 40 in my 2005 Outback.
