Results 1 to 10 of 15
    Oct 2009
    Tumwater, WA
    Default Ballast upgrade question
    Ok I'm upgrading my GIII system. I'm gonna use the factory rule pump for my front bags and get 2 new pumps for the rears, and get rid or the sprinkler system.
    1. Should I use 1 big thru hull and make a manifold with the 2 pumps (one for each side) or should I make 2 small (3/4) thru hulls each with a pump.
    2. What pump to buy. I'm leaning towards the tsunami 1200 so I can use 1" tubing. I know there are issues with the threading but can't I just use a 1" tube with a hose clap to connect it to the thru hull?
    I also noticed on wakemakers website they have a different pump and it says it's faster but it's an 1100 I don't remember what it's called but I'm looking into that pump as well.
    I have read, and read all the ballast upgrades on here and am stealing all these ideas from you guys so thanks in advance and any info would be great!!!
    2006 Outback V, Alpine CDA-118M, 2 alpine MC20's, Polk Cabins, 2 Exile XM7s 2 SXT65s (tower), Memphis Mojo 12" Sub in custom downfiring ported box, Kicker 2500.1, Exile Harpoon, JL M6450, WS-420.
    Acme 1433, 750lbs Sacs in Rear, GG 1180 (fills to about 700) Sac in Center Locker, 650 lbs Nose bag.
    PP Stargazer
    1 big hole or two smaller ones probably doesn't make a whole lot of difference. You might think about if one bag is larger than the other (or are you running 2 750's?). If so, it might be nice to be drawing from the bigger fitting while you are finishing the larger bag.
    Oct 2009
    Tumwater, WA
    Yes I have 2 750 in the rear.
    PP Stargazer
    Des Moines, IA
    Lot's of good ways to do it. I'd probably add 1" thru hull with a tee to feed 2 rear pumps, and leave the factory thru hull and Rule pump alone to feed the front.
    If you use the "T", if one pump goes you are still operable too.
    Oct 2009
    Tumwater, WA
    If I use the T each side goes to it's own bag. So it wouldnt work if one died. But I'm not worried about that.
    Is the tsunami 1200 the way to go??
    PP Stargazer
    Nov 2003
    Land O Lakes, Florida
    I'd recommend 2 3/4" thru hulls for the new tsunamis-
    3/4" thruhulls are a bit cheaper than 1" and will flow plenty of water
    Tsunamis are the way to go, simple, flows the most water and cheap. just make sure to get the fittings to fit 1" hose.
    keep the factory pump for the front bag
    If you like I can try and get a photo of my system using tsunamis
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    3/4" thru hulls will be cheaper than 1", but remember you will need 2 which is probably more than the other fittings that would go along with 1" a T-setup. Plus you'll be adding another 3/4" ball valve with 2 thru hulls so your price goes up more. The 1" T-setup will be longer/bigger than individual pumps would be, which may be trickier to mount, but can be done.
    Apr 2010
    saskatchewan, canada
    I just ordered all my parts to upgrade my system, I did quiet a bit of research on this and went with the reversible johnson pumps, I know they are more money but by the time you add in your drain pumps it is not going to be a huge difference in price. they are suppoesed to fill a 750 in 6 min. I have had problems with all of my drain pumps (aretor style) where they have had to be replaced so I thought this time I would put the same pumps that are put into all the new moomba, supra, mastercraft ect.
    2005 Mobius LSV
    Gravity IV (750s rear, 400 mid and 650 bow)
    wakeplate, perfect pass,
    Not sure what stereo I have, but I have 3 amps 2 subs 6 x 6.5 mids and tweets and 4 tower speakers ( 2 x 8 inch and 2 x 6.5 and tweets)
    Fuel Injected
    1433 acme prop
    wakemakers now has a thread end for the tsunami 1200
    http://www.wakemakers.com/attwood-st...00-3902-1.html
