Results 1 to 3 of 3
Thread: WATER TEMP RUNNING HI
06-13-2005, 11:04 PM #1Junior Member
- Jun 2005
- 3
WATER TEMP RUNNING ABOUT 210!! LOOKED AT PRIME PUMP LOOKES
GOOD HAS 350 Hr ON BOAT.DONT KNOW IF THE MAIN WATER PUMP
IS WORKING OR NOT DONT LEAK WATER.HAS 5.8 351
IF YOU KNOW WHAT THE PART# FOR THE WATER PUMP OR WHAT TO TRY
LET ME KNOW THANKS TERRY
06-14-2005, 12:02 PM #2Brian Raymond Guest
Replying to Topic 'WATER TEMP RUNNING HI'
First check the intake side of the transmission cooler. It is a cylidrical 9" in-line radiator for the trans. fluid, on the port side of the motor in-line with the water intake hose. Remove the hose and check for weeds and debris in there. If all checks well, Check the impellar for wear or missing blades. Keep us posted. Brian Raymond
06-14-2005, 12:07 PM #3Junior Member
- Jun 2005
- 3
JEFF
Boat has strainer at bottom inlet and one at the oil cooler. Are you talking about an additional one? I have checked all lines for debree. Primer pump, impellor. Thermostate working properly, has 180 degree thermostate in it. Is there a way to run the boat out of the water to test it? In need of help bad. Could this be the main water pump problem? What would be the cost of a water pump?
Information appreciated.
Water Temp
By pullmyfingers in forum Skiing & SlalomReplies: 17Last Post: 04-09-2008, 10:39 AM -
Water temp gauge
By gsi09907 in forum General ChatReplies: 7Last Post: 07-03-2007, 06:21 PM -
Running out of water
By rshea99 in forum Service & RepairReplies: 9Last Post: 06-25-2007, 09:30 AM -
Drysuit/Water temp
By waldofrog in forum General ChatReplies: 4Last Post: 10-02-2006, 10:57 PM
