Results 1 to 10 of 12
    Jan 2010
    North Texas
    Default Think this impeller is bad?
    You tell me. Pulled this out today.
    2006 Supra 20 - Sold
    2015 Supra SE450
    Apr 2008
    California
    It's not missing any pieces, that's how they all look after awhile in the housing and the new one will look the same way in no time. I change mine every three years on average but it all depends on the water you boat in and debris, etc. Biggest reason to have a raw water filter otherwise make sure the inside of the housing is smooth as silk, no burrs at all. If it does use 2000 grit wet sandpaper to smooth it out lightly.
    Calgary Alta Canada
    Surprisingly its likely not all that bad if you were to clean it up. I've seen worse. Having all the veins intact etc and minus the calcified water spotting its likely not too bad.. Change it just the same seeing as its out now....
    07 Outback DD
    Mar 2008
    Vancouver WA
    As long as the veins aren't brittle feeling, I'd at least keep it as a spare. Looks a little rough but they all do after a while.
    PWI as usual...
    when i changed mine last year the old one still looked brand new. ill be putting a new one in in a couple weeks so it will be interesting to see how the current one faired over 100 hours last summer
    Sep 2009
    Grayson, Georgia
    Does anyone take them out over the summer? I was always under the impression that you were to take it out over the summer and seal it after lubricating it.
    -Mark
    2005 LSV
    Tow w/:
    Volkswagen Touareg V8
    -John Wooden
    Quote Originally Posted by WaterBullDawg1980 View Post
    mine gets a lot of use during the summer
    Sep 2009
    Grayson, Georgia
    Ha! Good point. Can a mod hook a brother up with an edit por favor?
    -Mark
    2005 LSV
    Tow w/:
    -John Wooden
    Sure, but only after many more have seen your post and mocked you mercilessly.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Sep 2009
    Grayson, Georgia
    What's fair is fair. I stand in silence for my public flogging.
    Sent from my Kindle Fire using Tapatalk
    -Mark
    2005 LSV
    Tow w/:
    -John Wooden
