Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
    May 2008
    Default Engine problems from spain
    We need help. We hava changed the full pump. fuel filter,
    impeller, spark plugs.Oli levels are perfect.In Spain don´t have service.
    We don´t find the problem.
    Does anyone have conecctión check and software for the engine??.
    Where can i buy the conecction check and software?
    Indmar 5.7l 325 hp.The boat has 330 hours.
    http://www.youtube.com/watch?v=PrjoPwdsn_8
    Thanks.
    Hi guys, It's my firends boat. We would really apreciate any help on this.
    I think we've tried it all by now.
    For some reason the boat jumps in the "limp mode" and we can`t find out why.
    Any suggestions?
    Sep 2008
    Sweden
    Hi there.
    I get the same problem if i use the cruisecontrol and don´t turn it off after stoping. Check if cruise control is on and turn it off.
    Aug 2010
    Acworth, GA
    Tell us more about the boat like Year and Model, does it have Moomba Crusie, Perfect Pass? Has it ever run properly for you or is this a new problem?
    As superfet noted Moomba Cruise can cause the engine to behave as you descibe if it has been left on after the engine has been turned off.
    Kraig - 2010 Outback V
    Mar 2008
    Take a look at your oil level transmission level. That will put your boat into limp mode. Also sheck your impellar. You should be running around 140F. Looks like you were getting higher than that.
    PWI as usual...
    140??? im usually around 160, 140 seems wayyy cold
    Tuscaloosa, Alabama
    I am at 160/170
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Engine water temp also has to do with your location, here in the NW where water is 60 all the time it will run cooler then in TX and AL where the water is in the mid 80s to 90s
    Feb 2009
    Wausau, WI
    To me it looked like the cruise switch was in the "on" position.
    Matt
    May 2008
    Arek, Thanks a lot.
    Superfet, the problem occurs with the Moomba Cruise on and off.
    It hasn´t Perfect Pass.
    KSmith, the first time was in the summer of 2009, only one fault and
    we didn´t give its importance.
    2010, at 10 hours a session occured twice and three times
    with food and beer whem it occurred the fault.
    A day didn´t fail and the next day the problem was constant.
    In summer of 2011 we changed the fuel pump.
    I was well the first 4 hours after failure, this video is
    from october 2011.
    Newty, the impeller has been changed before and after the problem.
    Here in Madrid, usually 140 at 160F. All Oli levels are perfect.
    Hoopskier, the moomba cruise was in the “on” position and “off” position.
