    Jun 2005
    Default How to drain gas tank
    Does anyone know 'How to drain Gas tank,' for the outback LS 2000 model?
    Jul 2003
    Carson City, NV
    Default Replying to Topic 'How to drain gas tank'
    Why are you doing that?
    Mar 2003
    Springfield Missouri
    If you need to get the gas and any other liquid (water?) out of the tank, I would recommend disconnecting the gas line after the fuel pump and place it in a gas can and run a 12 volt source to the fuel pump. Energize the pump away from the engine compartment to eliminate a spark and the potential for a kaaboooom.
    1998 Mobius
    310 HP PCM
    SOLD
    May 2005
    Mooner
    Here is a "getto fabulous" or "backyard" way to do it. Pull you gas line off. Extend the hose or whatever you have to do (get a longer temporary line) to get it down through you drain hole under your engine compartment (I have an inboard). Place a container down there (hopefully the tank is not full). Then, go to the fuel overflow fitting on the outside of your boat. Take the cap and the thingy off. Blow into the overflow fitting and put you hand over it quickly. If you have a tube inflator, it will work also. This will pressurize the tank and "push" the fuel out. You may have to do it a few times and it will take a little time, but it will work. I don't recommend the "blowing into it method", but it works when you are in a fix- the fumes are a little tuff to deal with. Of couse zabooda's method is probally a little smarter!
  1. oil drain on 05 XLV?
    By tlatoani in forum Service & Repair
    Last Post: 04-25-2008, 11:11 AM
  2. Drain my fuel tank..Engine bogs down
    By titan2539 in forum Service & Repair
    Last Post: 11-04-2007, 03:01 AM
  3. water won't drain
    By desert wake 360 in forum General Chat
    Last Post: 08-07-2007, 09:24 PM
  4. Battery Drain
    By Bobby in forum Service & Repair
    Last Post: 10-25-2005, 05:24 PM
  5. Bilge drain
    By silverski in forum General Chat
    Last Post: 06-06-2005, 11:16 AM
