Page 15 of 15 FirstFirst ... 5131415
Results 141 to 147 of 147
Thread: Duramax Chat
  1. #141
    so the trans problems that plagued dodge were primarily for the 2500 and 3500 series trucks?
    Yes because people who buy the 2500 and 3500 got the same transmission in your 1500.
    SO if you tried to pull 10K with your truck the engine would be lugging really bad and the trans would over heat or break down eventually. This isnt as known of a problem with 1500s because the truck is weighting in at 6K instead of 8k and most 1500 owners arnt trying to pull 10K plus trailers.
  2. #142
    Ok then I won't worry about it. The only think I pull is the boat I estimate it is (
    5000 with full fuel and gear
    2017 Moomba Mojo Max Surf Edition, 2 Pair Wetsounds Rev10s powered by an SD2, 6 paid Wetsounds XS650M and Wetsounds WS12 powered by SD6 all controlled by a WS420.
  3. #143
    Yea i wouldnt worry about it to much but with you travel milage and towing as much as you do, if be looking at getting the trans service every year change the fruild and filter. That will keep the trans happy. Might even look into a transmission cooler also if you dont have one.
  4. #144
    i have a cooler and when i bought the truck carfax showed that the trans fluid was changed at 50,000 miles and i just changed it again last thursday with like 78,000 on it. i will probably change it every 30k
  5. #145
    Aug 2009
    Montana
    Why Dont you sample the fluid annually and the lab tests will indicate when it's time to change and can give advanced notice of minor and major service issues. Fleets have been doing this for years.
    I started it after talking to an engineer of Allison for over 20 years and he indicated its not uncommon for someone running transynnd in there allison under normal conditions to go 150000 miles on there tranny before needing a change.
    The stealerships want people to come in regularly for stuff they don't need. It's a huge money maker
    If you really need a change every 50000 then tests will determine that based on the breakdown.
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
  6. #146
    Thought my buddy Dusty had decided to come visit the ATL. Saw this rig in the rearview and was disappointed when it passed & I saw the GA tags.
  7. #147
    Aug 2009
    Montana
    11outbackV -
    ever get ur truck done? Pics................?
    2015 "NOT A MOOMBA"
