Results 1 to 6 of 6
Thread: Prop shaft packing adjustment?
06-07-2005, 07:21 PM #1
Should the packing be adjusted with the boat idleing in gear, or just sitting in the water? Right now it drips once a second so I know it needs a little tightening up.
jy
06-08-2005, 01:41 PM #2Brian Raymond Guest
Replying to Topic 'Prop shaft packing adjustment?'
All the pre-adjusting should be done in neut. in the water. When finally adjusted, you should have one drop of water while in gear at idle. If you should have further questions in regards to this procedure, you can contact; [email protected]. Hope this helps, keep us posted. Brian Raymond
06-08-2005, 01:44 PM #3Brian Raymond Guest
Did not proof read last post, sorry. It is one drop of water, in gear, at idle every 30-45 seconds. Brian Raymond
06-08-2005, 03:39 PM #4
Thanks Brian,at first I thought you meant " one drop forever".
jy
06-14-2005, 08:16 PM #5Member
- Nov 2004
- 45
Hello all,
Would anyone happen to know what size wrenches fit the packing nuts? I have to put together a tool kit from home for our next trip up to the cottage. Thanks.
Dave
06-15-2005, 05:32 AM #6
I used large Channel locks. My largest wrench is 1 1/4 which isn't big enough.
jy
Shaft packing - what size?
By NH Moomba in forum Service & RepairReplies: 5Last Post: 04-26-2006, 07:35 PM -
Prop/Shaft Damage?
By Nboard10 in forum General ChatReplies: 10Last Post: 04-03-2006, 03:12 PM -
Shaft Packing
By qb12 in forum Service & RepairReplies: 8Last Post: 06-10-2005, 05:47 PM -
Access the Shaft Log Packing Nut
By broncogeoff in forum Service & RepairReplies: 9Last Post: 05-06-2005, 06:52 PM -
Shaft Seal Packing and Sealant
By in forum Service & RepairReplies: 4Last Post: 06-23-2003, 07:42 PM
