Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Arkansas
    Fargo, just want to clarify, you were pleased with your Tahoe setup? I was looking at one that goes in center console. Have you ever swapped the sub out or are the boxes designed for the jl sub that goes in?
    Sent from my DROID RAZR using Tapatalk
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  2. #12
    Jan 2010
    North Texas
    ^ To go a step further, the Jl Stealthbox for his console is $600 with the JL sub included. Compared to a standard "under the seat" truck box with an equally powered 10" sub how would you compare it? I may be in his same boat here if things work out with a new truck and I'm on the side of that Stealth box, aside from the cool factor of completely hidden being a waste when it comes down to final sound. If I'm wrong...I guess I will end up ponying up!
    2006 Supra 20 - Sold
    2015 Supra SE450
  3. #13
    Fargo ND
    the sub seems specific enough for me to not tinker with, and I havent been dissappointed with the way any of mine have performed. the center console one took up most of the room in the console, sounded awesome, but took a lot of space that I need. the behind the seat will make you recline the seat very slightly, (I dont think anybody wants them straight up and down anyways) and there is plenty of room regardless. I almost sound like I should be geting paid (I dont). my old man just put one in the back of a 2011 sequoia, the guy sold him a Stealth box, then proceeded to install a JL sub in a wood enclosure that they made to fit for $50 less....doesnt sound the same, rattles, fit is not snug.....worthless and taken back and replaced with what was ordered. I believe the expense is the mold that they have to make to make the box fit perfectly and it is obvious and sounds perfect. I can email you pics of mine (behind seat) and one that is in a 05 tahoe here at work that is in the console so you can see the space "issue". maybe you know how to post them here. PM me if you want me to do that. sorry for the windy reply
    06 Mobius LS
  4. #14
    Nov 2009
    I wouldn't mind seeing the one in the center console I always wanted to get one i just didn't know if I wanted to shell out the dough. BTW 04 Z71 Tahoe.
    -Mark
    "Hey you only live once"
  5. #15
    Aug 2009
    Montana
    As an added note..........they don't make the JL stealthbox for every make and model. IF they did, I'd be running one now And they come factory color match enclosure to look OEM. Sometimes don't even know they are there until you turn it on or up! For alot of vehicle you have to build your own
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
  6. #16
    Arkansas
    Viking, don't you have a lmm? They have one for both the bench and center console I thought. I was looking at the center console. Do you have rear air vents?
    2016 Moomba Mojo
  7. #17
    Aug 2009
    Montana
    LBZ..........and yes it has buckets with the center console with the rear air and rear radio controls.
    I like that aspect but don't like that there isn't a JL SB for it
    Prob gonna get a custom jobber made for behind the rear seat at some point
    2015 "NOT A MOOMBA"
  8. #18
    Feb 2010
    Canton, Ga / Lake Lanier
    Quote Originally Posted by FargoDawg View Post
    I have the Crewmax, the stealth (if I remember right) is a 12.25 inch.
    It's a 13.5 3 ohm. I think I'm going to pull the trigger shortly...once it's installed I'll decide if I'm going to go with 2 or not...hopefully one will be enough. If it's too loud then you are too old!!
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  9. #19
    Feb 2009
    Wausau, WI
    Selling an extra part from my install
    Toyota speaker adapter plates. Allows the use of aftermarket 6x9 speakers. Bought for my Tundra but should work for other models-FJ, Tacoma. Purchased from Tacotunes.com. You get the pair of adapter plates and adapter harness-no need to cut your OEM harness.
    NOTE; you will need to provided your own hardware
    NOTE: This item is 1" thick and allows for a top mount depth of approximately 2.95 inches
    Asking $30 shipped. Cash, Check(pending clearing), money order.
    Matt
