Thread: Rubber Hose
06-06-2005, 02:00 PM #1Junior Member
- Jun 2005
- 2
Rubber Hose
I have a 2002 Outback with a 310 Carb. Im not very mechical. SO here goes.
There is a black rubber hose that exits out the rear of the air filter then goes into the cylinder head. This hose is always coming out at the cylinder head. I installed a hose clamp to hold the hose in place. However it appears it might come out over time.
What will happen if this hose comes out.
Thanks in advace
06-06-2005, 02:15 PM #2Junior Member
- Feb 2005
- Calgary, Alberta Canada
- 13
Replying to Topic 'Rubber Hose'
Sounds like the PCV valve tube. Positive crankcase ventilation. You really do need it
06-06-2005, 03:18 PM #3Junior Member
- Jun 2005
- 2
I spoke with my dealer, he is going to ship me out the rubber piece that fits into the cylinder head. They say if it comes out while running it may run alittle rich or oil may spray around inside the engine compartment.
06-08-2005, 08:24 AM #4Senior Member
- Mar 2004
- Wylie, Tx.
- 212
My PCV hose is always a little loose, but that is one of the things that I check before I hit the water. It drives the wife and kids crazy every time I do my "preflight" check but it has saved me once before so it is justified. After de-winterizing, I had left on of the hoses off under the exhaust manifold that comes straight off the impeller discharge. Man will that fill the hull up fast!
MedicMedic151
06 Mobius XLV
Bilge Flood/Hose Broke
By carsondoc in forum Boat OwnersReplies: 8Last Post: 08-27-2010, 01:21 PM -
Removing the water intake hose?
By LSV04 in forum Service & RepairReplies: 2Last Post: 04-27-2008, 08:15 PM -
Ballast question...3/4" ID hose?
By TL7 in forum General ChatReplies: 3Last Post: 02-05-2008, 07:22 AM -
Winterizing - flush kit hose size
By jared in forum Service & RepairReplies: 1Last Post: 11-08-2007, 11:29 PM -
Quick-disconnect hose
By canuckskier in forum Service & RepairReplies: 5Last Post: 10-16-2006, 03:18 PM
