Thread: wake plate
02-03-2012, 09:57 PM #1Junior Member
- Sep 2011
- 1
wake plate
Can you put a wake plate on an 2006 Ls dd .i need a bigger wake
02-03-2012, 10:25 PM #2
I don't know how the transom is set up on your boat but what you need is ballast. The wake plate will shape the wake but i don't think it will not make it bigger. I anything it may squash the wake. The biggest wake is achieved when the plate is all the way up which is very similar to no wake plate at all.
I am not the expert here so you may want a second opinion.2018 Max with a little extra weight here and there
02-03-2012, 10:29 PM #3
I second that! Sack it out with Ballast or peeps is what you need. Wakeplate will just help "shape" your wake.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
02-04-2012, 12:06 AM #4Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
A wake plate will help slightly at slow speeds,But as speeds come up the plate will actually lift you out slightly,thus making a flatter wake. Weight is what you want to increase the wake size of any true significance.
07 Outback DD
