Results 21 to 30 of 30
Thread: Trailer woes
01-29-2012, 07:56 PM #21Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
01-30-2012, 12:53 PM #22
Thing is there is not much rust anywhere else on the trailer. Or at least not what I would consider excessive for a boat trailer. Just on the calipers. The boat don't really have much rust anywhere except on the worm clamps around the dripless shaft seal and I replaced those
02-03-2012, 12:19 AM #23
Does anyone use bearing buddies with the Vault grease or did you swap to normal grease for bearing buddy use?
02-03-2012, 10:25 AM #24
I think that's apples and oranges.
02-03-2012, 11:14 AM #25David
02-03-2012, 12:08 PM #26
My Trailer had Bearing Buddys already, I fill them once a season and there Good! I use a marine grade grease in them. And Yes, you pull the cap, hook up grease gun and fill. Its easy. Never heard of Vault grease.
Rick
2002 Moomba Mobius V
02-03-2012, 01:24 PM #27
David I did the conversion last season when I noticed oil leaking from two seals in the rear of the hubs. After finding out that 1) the oil bath system is discontinued, 2) the oil bath seals are hard to find and 3) I couldn't get the stupid tiny allen fills out, it was a no-brainer for me.
All you need is the Bearing Buddies (or your equivelent choice) and regular trailer grease seals. I used marine grease and they've worked perfectly.
After you do the conversion and fill with grease drive it around and fill again as the grease will pack in due to centrifugal force. You may have to do this a few times before the buddies quit recessing in. I carry a mini grease gun in the truck for just this reason.Last edited by Razzman; 02-03-2012 at 01:27 PM.
02-03-2012, 01:39 PM #28
You really didn't have to change bearings or anything, just seals? Sounds like a decent plan.
02-03-2012, 01:40 PM #29David
02-18-2012, 10:17 PM #30Junior Member
- Apr 2009
- Okanagan
- 19
The cracking often occurs when hot rotors get submeged in water. The vault hubs have a long warranty period so you might want to talk to boatmate or ufp about that. Also the vault uses a special hybrid type grease so mixing the
greases will likely not be good nor keep your warranty valid.
