Results 1 to 9 of 9
Thread: To winterize or not?
02-11-2012, 11:54 AM #1Junior Member
- Jan 2012
- Evans GA
- 2
I have an 07 Moomba Outback Direct Drive... im in South Central GA and we have had a very mild winter.. I actually took my boat out a few weeks ago and ran it.. My question is we have some 20 degree nights up ahead.. what steps should I take if any to protect my engine from freezing? it is stored indoors but not climate controlled.. Thanks BK
02-11-2012, 12:10 PM #22007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
02-11-2012, 12:16 PM #3
Better safe than sorry, that cracked block will be a huge bill if it's not taken care of now. Peace of mind alone I would say its worth it, just my .02
2009 Moomba Mobius LSV
02-11-2012, 12:52 PM #4
02-11-2012, 02:47 PM #5
What is the temp indoors? In an attached garage you will probably be fine but can throw a trouble light down by the engine to be safe. If it's a standalone storage building, garage or shed you better drain like they say above. I put a thermometer and a bowl of water in my garage on the coldest nights. My temp never got below 40 so I quit worrying about it.
02-11-2012, 03:42 PM #6
In MT I drain and then flush with anti-freeze just to be sure. But it's not uncommon to have 3months straight of freezing and sub-zero temps. In your climate, I would agree with what has been advised and just drain everything for piece of mind and it'll take you less than 20min. to do it.
2015 "NOT A MOOMBA"
02-11-2012, 10:44 PM #7Junior Member
- Jan 2012
- Evans GA
- 2
Thanks... I went and drained the two plugs on each side and the exhaust manifolds there was a lot of water in there... First inboard so this was new to me...
02-11-2012, 11:06 PM #8
Good man. Now, plan ahead for some routine/preventative maintenance. Order an impeller for the raw water pump. Keep the used one in the glove box as backup and install the new one come spring. Fins that have separated from a broken down impeller will wreak havoc on an engine's cooling system. Also, schedule time to change the oil and filter. These three items, like draining the engine and manifolds, are easy on the Outback with its engine smack in the middle of the boat.
2012 RAM Crew Cab
Stuart
02-14-2012, 12:47 PM #9
i agree that if it is detached garage you should drain it for peace of mind.
I've spoken with a dealer in WI before and they said below freezing temps for less than 24 hours won't do any damage. So even though it gets down to 20 at night, so-long-as it is in the 40's during the day you shouldn't have any problems...I can't wait to start storing mine in my garage next year'00 Moomba Kamberra
'99 BMW 528it
