Results 1 to 9 of 9
    May 2004
    Maryland
    Default Trailor Question
    Are the brakes on the trailor used during normal driving or only for break away?
    Looking at the 5way flat to 7 way round trailor connnector i realized that there is a prong missing where the electric brakes should be. Any Ideas?
    Dec 2004
    Cinci-Dayton
    Default Replying to Topic 'Trailor Question'
    Which prong which side? The flat 4 adaptor has l, r, tail and ground, no brake.
    Flat five has a brake. Sounds like you have a flat 4 which you should not use.
    You do use the trailer brakes on the road. I have a Suburban and woudl not run without it.
    SD2
    Naked red and white 2005 Moomba LSV
    Jul 2004
    Lake Elmo, MN
    The brakes do work all of the time. However, they are not electric brakes but just surge brakes. They are activated when you brake your vehicle which puts pressure on the hitch that activates the brakes.
    The 7 wire assembly from you vehicle includes the ability for electric brakes but that does not apply to this trailer. That is why they only use the 5 prong plug. The 5th prong actually is linked to your reverse lights that sends a message to the trailer to dissengage the surge brakes to allow you to back up.
    I think that is what you are looking for.
    Guest
    I see what you all are talking about. I do have the 5 flat. Just wondering because i have a break controller and other trailors i tow with breaks (ATV's) show up on the break controller. Nothing from the moomba trailor though. I do feel the the trailor pulling away from the stoplight. Thanks for the help. I may just consult my local hitch and trailor store.
    Dec 2004
    Cinci-Dayton
    oops Silverski is correct.
    I was unable to find a hole in the ground today (went lookng for it twice). I think I will just call it a day.
    SD2
    Guest
    Thanks for the help, i figured they were only surge breaks but i wish they were regular brakes. Any way to convert?
    May 2004
    Maryland
    Thanks for the help. I well now its cleared up they are only surge brakes, why this design? Any way to convert to regular brakes?
    May 2003
    south east michigan
    Electric brakes tend not to work well on boat trailers.(too much getting wet).The surge disc brakes on my 03 Outback LS trailer are the best I've ever had.
    jy
    Mar 2005
    No problems with my new trailer either, its a single axle, was a little skeptical at first, but this is by far the easiest trailer Ive ever pulled.
  1. mobius V trailor
    By pike1990 in forum Service & Repair
    Last Post: 05-28-2003, 06:44 PM
