Results 1 to 10 of 13
01-18-2012, 01:17 PM #1
Suggestions on where to purchase starter
I am 90% sure my starter is going bad. I will test it this spring to be sure. It seems like replacing the starter is pretty easy. Does anyone have any suggestions for locations to purchase a marine starter online?
Also.. I remember somone saying there is some switch that if you change the starter you ought to change. Any pointers on what that would be?
-- bk2003 Mobius LSV Gravity Games
Total Noob running 1100 in the center, 750s in the lockers.
JL JX360/4 powering 6 Infinity 621m speakers
01-18-2012, 01:41 PM #2
The Indmar number is S571006. The Arco number (aftermarket) is 57-30470.
I think I ordered the aftermarket from ATL Marine. That is for the 340 cat motor.
You can call ATL Marine and they will give you the part numbers and prices. Do a google search with those numbers and unless you find something way cheaper, I'd just order from ATL. That's what I did anyways.Last edited by KG's Supra24; 01-18-2012 at 01:43 PM.
2016 Moomba Mojo
2006 Supra 24SSV - Traded
01-18-2012, 03:16 PM #3
Thanks. Is it an easy repair?
01-18-2012, 03:22 PM #4
Mine was pretty easy to access. It's an easy swap as long as you can access it easily.
2016 Moomba Mojo
01-18-2012, 03:45 PM #5
Find an altenator/starter repair shop and have it rebuilt. Typically they'll give you a lifetime warranty and it will be quite cheeper than new. I payed $28 to have the one on my jeep rebuilt. I know its not a marine starter but if you have the marine starter to begin with you the guts are the same. Definatly the way to go. my.02
PWI as usual...
01-18-2012, 03:54 PM #6
Having one rebuilt is also an option.
Here is the thread I started from when I was having a similar problem ...
https://forum.moomba.com/showthread....er+part+number2016 Moomba Mojo
01-18-2012, 06:47 PM #7Senior Member
- Dec 2006
- Tuscaloosa, Alabama
- 815
Maybe try discount inboard marine but I would try the rebuild thing too. Prices on starters/alternators are really inflated. I have had good luck with skidim and they are knowledgeable and will answer questions.
Jack Beams
'05 Outback DD
325HP EFI Indmar
01-18-2012, 08:39 PM #8
Just a reminder to stay with a marine starter.
1998 Mobius
310 HP PCM
SOLD
01-19-2012, 11:18 AM #9
^^^^^^^ Of utmost importance. Marine starters are built differently to ensure no sparks which could ignite fumes
Kraig - 2010 Outback V
01-20-2012, 12:41 PM #10
yup, having it rebuilt should be no more than 1/2 the price of a new or reman. Most places rebuild marine and non-marine applications.
'00 Moomba Kamberra
'99 BMW 528it
