Results 1 to 6 of 6
Thread: 2001 Outback Fuel Tank
06-01-2005, 04:22 PM #1Junior Member
- Dec 2004
- 20
I was told that the Outback fuel tank was plastic and was located under the floor of the boat. While replacing my fuel check valve on my 01 I noticed my tank was metal and it sat behind the false wall under the seat??? What gives???
I was considering putting a fat sack in the trunk?
Jeff
06-01-2005, 07:38 PM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Replying to Topic '2001 Outback Fuel Tank'
Are you going to believe what you were told or your lying eyes?
My 05 manual shows the V drive tank under the seat and the DD tank way in the back.
SD2Naked red and white 2005 Moomba LSV
06-01-2005, 08:49 PM #3Junior Member
- Dec 2004
- 20
I know what you're saying. Maybe the person that was talking about the 01 with the plastic tank under the floor had an LS. Mine is a non LS and the tank is absolutely not plastic and it's right behind the false wall.
She ran like a scalded dog tonight. I think the fuel issue is solved.
BUT............................now I found two more issues. The dash is shorting out and making the gauges bounce and motor cut off......anytime you push against the dash. Gotta pull it apart and see where it's grounding out.
AND the shaft is leaking like the Titanic. Time to check the packing. Easy fix at least.
I hope this weekend goes ok with nothing to worry about except not faceplanting on the wakeboard and making sure the beers stay cold.
06-01-2005, 09:22 PM #4Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
It rained a little last weekend. I would have sworn my boat had a leak but my Lund docked next to it also pumped a lot of water. The first night at the dock I woke up twice to check on the boat. Each morning I would rock the boat, watch the bilge and think of that guy in Canada that parked his 05 boat on a quiet little dock and left for six weeks.
I read that on some older boats the short could be in the box mounted under the dash. The bouncing around worked the box and some components lose. One guy pried it open, cleaned it up, tightened it up (he may have soldered some components) and it worked fine. I believe the boxes are expensive. FYI if you do not find a nice bare wire someplace.
SD2
Attached is a picture of my two boats at the dock. I miss the lake already.Naked red and white 2005 Moomba LSV
06-01-2005, 10:07 PM #5Junior Member
- Dec 2004
- 20
I would worry about leaving my boat for 6 minutes, nevermind 6 weeks!!!!!!!!!! I took a look under the dash and the board that all the switches are mounted to is rubbing the dash. I am going to try and clean it up and epoxy some rubber spacers or something to keep it from happening..........
Sweet boat. Is it the LSV? We are going to get a V-Drive next season. I am going to look at the Malibu VLX, Correct Craft Super Sport, or a Mobius LSV. Probably something with under 200 hrs or so................
Jeff
06-01-2005, 10:37 PM #6Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Yep Mobius LSV. In a world where more & more boats are being built to be SUVs, this one is still a sports car. It is a hoot to drive. I just broke 10 hours over the weekend so I am by no means an expert - but I really like it.
SD2.Naked red and white 2005 Moomba LSV
Fuel Tank Vent
By cj11302000 in forum General ChatReplies: 4Last Post: 09-02-2020, 10:51 AM -
Outback LS - plumbing in factory tank
By stuey in forum Wakeboarding | WakeskatingReplies: 5Last Post: 04-21-2008, 10:32 AM -
Drain my fuel tank..Engine bogs down
By titan2539 in forum Service & RepairReplies: 3Last Post: 11-04-2007, 03:01 AM -
Fuel tank level during storage
By chpprpilot in forum Service & RepairReplies: 1Last Post: 07-28-2005, 03:18 PM -
2004 Outback Fuel Tank Size
By sladey99 in forum General ChatReplies: 0Last Post: 11-23-2003, 09:09 AM
