Results 1 to 10 of 10
Thread: engine walls
01-15-2012, 01:08 PM #1Junior Member
- Jan 2012
- 9
engine walls
Im new to the forum and to moomba. We just bought a 2000 mobius v and we love it! Being a used boat it has seen its share of owners and one previous one was nice enough to remove the covers or walls on either side of the engine under the cover. Now it is difficult to use the space for storage due to melting things and moving belts... What would be a good material to bolt to the ski pilon frame to use to make a new wall?
01-15-2012, 01:21 PM #2
There's some stuff called "boat board" which is basically like a thick plastic sheet. It is spendy stuff but you can cut it like plywood, screw into it, etc. Then cover it with marine carpet on the compartment side. If you can't find that you could probably get away with a marine plywood (actual wood). But personally I'd go for the plastic stuff.
I've seen smaller pieces at West Marine but they said they could order larger sizes.
My setup is basically the same as yours. My panels screw right into the aluminum braces that angle down from the front to back. I have a couple L brackets going up into the deck on the back, from the under side, that the panel screws to back there for support. It is very sturdy.So when is this "old enough to know better" supposed to kick in?
01-15-2012, 09:38 PM #3Junior Member
- Jan 2012
- 9
thanks! i googled it and it looks good. is there a heat issue next to the manifolds? imworried its too hot... is yours mounted on the inside or the outside of the ski pilon frame?
01-16-2012, 12:55 AM #4
No heat issues on mine - I have them mounted on the outside of the ski pilon braces, facing the compartment. Carpet on the compartment side only. When my ballast bags are loaded up they actually lean against the big fiberglass muffler thing across the back just a little and no issues still.
01-17-2012, 02:09 AM #5Junior Member
- Jan 2012
- 9
sweet! thanks for the pics. its good to have a visual of how to mount them. thanks for all the tips
01-17-2012, 09:48 AM #6
Now that's service! Nice job Berg.
