Results 1 to 7 of 7
Thread: Brake Bleeding PELA 6000
01-14-2012, 03:34 PM #1
I know there is a brake bleeding procedure for the trailer in which you use a screw driver to go up into a hole on the coupler to pry back on the piston to apply pressure on the brakes to get the air out.
I have a PELA 6000 and was wondering if I could use it as a vacuum bleeder by finding a hose to fit over the bleed nipple on the caliper and just sucking the air out and fluid through. Have anyone tried this?David
01-14-2012, 10:16 PM #2Senior Member
- Dec 2006
- Tuscaloosa, Alabama
- 815
I tried using a vacuum system to bleed the brakes and it didn't do very well for me. Now I am not the expert on this but I ended up using my truck to bleed the brakes by working the coupler. Took about an hour but it worked great!
Jack Beams
'05 Outback DD
325HP EFI Indmar
01-14-2012, 11:14 PM #3David
01-15-2012, 12:35 AM #4
A mityvac works the best. Buy one at Harbor Freight, then go to home depot and buy a tapered rubber plug. Drill a hole through it and insert the mityvac adapter/hose into it. Put the plug into the master cyl hole, put the other end on the pressure outlet of the mityvac. Put a hose on the bleed valve on the caliper and place it in a jar with brake fluid. Pump it a few times and crack the valve for a second or two. Gotta watch the fluid as it doesn't hold a lot of fluid. I can do both in ten minutes or so.
01-15-2012, 12:43 AM #5David
09-04-2012, 03:55 PM #6Senior Member
- Aug 2007
- Alpine, Utah
- 191
David, did the Pela work for you?
GarnGarn
2007 Mobius LS (Direct Drive)
09-05-2012, 09:31 AM #7
I also use a mighty vac setup. There is a mighty vac brake bleeding kit you can purchase
2005 mobius lsv 2900lbs ballast2005 mobius lsv
