Results 1 to 2 of 2
Thread: '01 Mobius running bad
05-27-2005, 11:22 PM #1Junior Member
- May 2005
- 7
OK. I have a '01 Mobius with the 320(?)HP throttle body injected Indmar. At the end of last summer it started running a little rich and I began fouling plugs bad. Gas milage was poor also, of course. It is smoking very bad (sooty, black). Runs great on a new set of plugs for about 1/2 a day and then the plugs foul and it is very hard to start. Due to it being very late in the season when this started happening, I did not take it into a dealer. I know this is sensor related problem (I have a TBI setup on a '87 K5 blazer and went through hell with some problems). Any TBI gurus out there? I did replace a temperature sensor (recommended by a friend) and it did not help the situation. Anyone know where to start? I have waited all winter and did not get it in to a dealer. Now, if I take it in, it is going to be forever before I get it back. Arrrr.... I want to ride! Anyone ever dealt directly with Indmar's tech dept?
06-05-2005, 10:47 AM #2Junior Member
- Jan 2003
- Vancouver , BC Canada
- 18
Replying to Topic ''01 Mobius running bad'
I would check your temperature gauge to make sure it is reading 170 - 180 because a stuck open thermostat will run the engine too cool which then tells the computer to run richer. Hope this helps
Seeking Flatwater
Running out of water
By rshea99 in forum Service & RepairReplies: 9Last Post: 06-25-2007, 09:30 AM -
2000 Mobius V will not stay running
By jjgleason in forum Service & RepairReplies: 4Last Post: 06-12-2006, 08:16 PM -
05 mobius not running
By 05mobiusxlv in forum Service & RepairReplies: 10Last Post: 07-10-2005, 04:04 AM -
Running out of balance
By Colorado in forum Service & RepairReplies: 5Last Post: 06-14-2004, 09:46 PM -
Running Hot
By wdf in forum Service & RepairReplies: 1Last Post: 06-26-2003, 10:08 PM
