Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Sep 2010
    Lake wallenpaupack PA
    Default G3 timer adjustment
    Not sure if this was ever put back up when the smeckle deleted all his posts. I had a copy so hopefully this works for others
    Sep 2010
    Feb 2012
    St. Albert, Alberta, Canada
    Thanks for putting this up. Changing the timer time is easy now, but I've got a few questions. If on a factory GIII all the bags are 400lbs, why is the front timer set to 3 mins? Should it not be set to 4.5 mins like the back? Also, I just upgraded to 750's in the rear, what should I set the timers to to fill them on a factory pumps?
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
    Belton, Texas
    Good question Krak. I also just upgraded to 750's and will have to adjust
    2009 Moomba Mobius LSV
    Wouldnt you just fill the new bag. 3 minutes then. Hit the fill switch again and count the time until it over flows out the thru hull. NOw got back and adjust the timers..
    Let me know on the 750 as well..I would guess 8 minutes.
    Belton, Texas
    I filled the new bags up, or close to, tonight with two hits of the switch. Let it sit for about two minutes before flipping to fill the second time. I'll have to get around to just resetting soon I suppose
    Feb 2010
    Canton, Ga / Lake Lanier
    I tried these instructions several times and couldn't get it to go into program mode. So since boat was dropped off at the dealer I'm having them do this...
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Sep 2010
    I used these for my 2010 lsv and it worked. It is a pita though u need to follow them to the T
    Feb 2010
    I found that my boat has a breaker by the batteries and then one in the engine bay labeled ballast. I tripped both of them in different combinations and tried it and could never get the pumps to stop turning on and be in program mode. It's probably something simple I missed.
    Does the 2010 have the reversible pumps like my 2011?
    *Side note*...I need to get some vent lines plumbed in this summer. I guess that's three more holes...
    Tow Rig:
    You should have vent lines for the GIII
