Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Kicker 10 L5's
    Nov 2009
    Default Kicker 10 L5's
    Hey Guys I have an 02 LSV and I was wondering if anybody has stuffed 2- 10 L5's under the helm. I am really considering it but I know it is going to be really tight. Would I be better off going with a 12 ported or 2 tens sealed. The only reason I am leaning towards the tens is because I have one already. Thanks.
    -Mark
    "Hey you only live once"
    Dallas, TX
    New Guy,
    When deciding which subwoofer is ideal for your boat always start with the external enclosure displacement first and go by the numbers. You can back out the materials, woofer displacement and port volume easy enough. In an open field boat the woofer surface area will greatly determine the maximum peak output. But past a certain point it is the enclosure that will mostly determine the deeper bass extension. Too much woofer in too small of an enclosure will result in more upper bass output but a premature reduction in deep bass.
    There are other considerations also.
    Your amplifier sub channel delivers alot more power into 2-ohms versus 4-ohms so look at the combination and final net load of the woofer(s).
    Two 10s are more surface area than a single 12 but dual 10s are more moving mass to drive and control. A good match in thermal power handling is important but a good match for command is a factor as well.
    The required displacement for two sealed 10s and a single sealed 12 will be similar. I would prefer a single 12 in a bass-reflex enclosure over dual 10s sealed in an open boat. The single driver bass-reflex will be more responsive and produce more output in the region of the bass that matters most. However, the leap to bass-reflex requires a big jump in enclosure displacement given the added port volume.
    The relationship between sealed and bass-reflex is not the same for all woofers.
    All the above and sometimes alot more must be part of the equation. Get with Phil from Kicker and see if he can put you in touch with an experienced Kicker dealer in your geo area. A good dealer will automatically take all this into account along with your particular boat and your personal preferences.
    Earmark Marine
    Feb 2008
    Traverse City, MI
    I have 1 10" L7 under the drivers dash in my Outback (and a second behind the observer seat), Im going to re-build and put both under the drivers side, but I haven't done it yet.
    Sent from my Kindle Fire using Tapatalk
    2013 Outback V
    Oct 2005
    Durham, NC
    I am curious about the benefit of multiple subwoofers. I have one 10" Infinity Perfect in a sealed 0.6 cubic foot box, with about 275 or so watts RMS running to it. I can't imagine having much more bass that that. It hits pretty hard, is quite loud, vibrates everything, and will "boil" the water outside up against the hull. I find myself having to turn it down frequently because it can become too much, and, well, my fiance gets pissed too.
    So I am asking the stereo expert guys like Phil and David and Brian how much having more can affect? If I have one amplified sub that plays at a certain loudess (just going to throw a number out here, say 100 db) if I double that to two subs I definitely don't have 200 db, so what is the benefit?
    Brian Roberts
    2001 Outback DD
    Dallas, TX
    Brian,
    If you double your 'amplified' sub you will pick up another 6 dB of output. 10 dB would be percieved as twice the volume so you would be a healthy increment of that.
    Two subwoofers in separate locations will not sum as efficiently as a symmetrical and compound arrangement in a single location.
    If you want to be "that guy" that when tied up can dominate several rows to the side and severals rows behind or you want the bass to extend out of the cockpit and beyond the transom to support the tower speakers at distance then you need much more subwoofer and subwoofer power.
    However, you can overdrive the inboat coaxials with too much bass if the in-boat listening is your primary focus. You will find that when listening to a subwoofer all by itself it will sound soggy and muddy with little to no bass discrimination (everyone should try this once). Add the coaxials and you will discover the pitch accuracy and tonal definition return to the bass. For musical sounding bass you need a precise balance between the fundamentals and upper harmonics. Pushing the subwoofer makes it sound remote or detached. It lessens the musical plausibility.
    It depends on your personal 'taste for bass', usage and music. Is it for dance, Hip Hop, a party boat, getting noticed and the like? Then you absolutely need more bass.
    Even if your taste runs a little more conservative I think clean bass is never hearing the limitations of your subwoofer or the power driving it. So personally, I always like extra in reserve because I have zero tolerance for over-driving equipment and the tonal aberrations that it introduces.
    Because I am so picky about the bass accuracy some of the best and most integrated systems I've heard used a 10-inch subwoofer or a larger subwoofer with larger 7.7-inch inboat coaxials.
    You just cannot impose your personal preferences on others. You have to be tolerant of others expectations. Its truly different sizes for different folks.
    Earmark Marine
    Oct 2005
    Durham, NC
    David,
    That is quite interesting. So a 10dB increase will sound like twice the volume. Okay, got it. And so each additional sub will add about 6dB. So I guess this is why the guys in the SPL challenges have so many speakers. It seems like the point of diminishing return can approach quite quickly, especially from a financial aspect.
    It is also interesting, as you mentioned, to hear the speakers separately. It takes a while to get used to tuning an system with the frequency's separated. Nothing really sounds "right" until I have all the speakers playing, but then it is harder for me to hear the distortion with them all playing. Most people who haven't heard this before are quick to comment how bad it sounds until it is all brought together. I re-tune mine every year at the beginning of the season, and it drives my finace crazy. I get the constant, "Are you done yet?" comments!
    I agree about having the clean bass. When I bought my boat, it had a JL MicroSub in it being run off a Hart Pro amp that had been turned all the way up and was running about 280W RMS to that little 8" sub. I was surpised that little sub survived. When turned up, it looked like it wanted to jump out of the basket, and it did not sound good. At low volumes, it was great, but it was just too small of a speaker for a boat, hence the upgrade to the 10" speaker.
    The JL 7.7s sound great. I am amazed at how much mid-bass punch they have. My buddies X2 has them, and at first listen, it sounds like the boat may have a small sub in it. But once you look at the poor speakers and see how hard they are working, you can figure out why the boat sounds like that. Are there other manufactuers make the oversized diameter coaxials?
    I guess the other thing that is frustrating for me is how the amount of bass varies from one type of music to the next. I wish my sub amp had a remote gain control to adjust it as I need it, but it only has one of those remote "bass boost" things, that I guess just adjusts the frequency at which the music is "boosted"? The result is similar to the remote gain, but not quite. How do those things work?
    While i'm on a roll with questions here, what ever happened to electronic crossovers? I had one in my car back in the mid 90s, and I thought is was a pretty neat piece of equipment.
    Anyway, sorry to hijack the thread and bombard you with all these questions. It is great to have your expertise as a resource on this forum. Thanks.
    Brian Roberts
    2001 Outback DD
    Dallas, TX
    Brian,
    Yes, 6 dB if you double the speaker AND power. And yes, the diminishing return comment is accurate especially with a limited voltage supply. SPL challenges are for short bursts only and the serious SPL vehicles would not make it as a daily driver when used that way.
    MicroSub...Nice little sub in its day. A bass-reflex has a steep rolloff below the tuning frequency and a smaller 8-inch would obviously be tuned a little higher. So the crossover frequency would need to be at least an octave higher than the tuning frequency in order to avoid a narrow and peaky response. It was probably crossed over too low and gained too hot. Plus a small bass-reflex sub really requires a subsonic filter to protect it below the tuning frequency where it acoustically unloads. That is another reason why you saw all the extra and wasted excursion.
    Later on the other questions.
    Earmark Marine
    Dallas, TX
    Brian,
    Continuing...
    JL Audio makes 7.7" coaxials and separate components. Rockford Fosgate has 8" marine coaxials. Of course they aren't going to fit everything. But when we've been able to use the larger 7.7"s with larger subs like 12s or 15s the seemless integration and bass quality was fantastic! Also, the second you add a subwoofer and highpass the coaxials, thereby limiting the speaker excursion and narrowng the amplifier bandwidth, the midrange clarity is dramatically improved.
    JL Audio has a line driver/controller that works great as a linear bass level control. The added voltage is a nice byproduct too. Its perfect for when some or all the electronics are on the passenger side because it does not extend the signal path. If either the HU or the amplifiers are on the drivers side then a PAC LC-1 is useful as a bass level control.
    Separate external electronic crossovers are still readily available but not as popular since amplifiers starting including that circuitry in everything.
    Earmark Marine
    Curious about this as well since I have a spare twin to my sub sitting on a shelf collecting dust.
    So if you build a single box to house 2 subs how do you figure out the size/volume requirement? I am currently running a 12" Polk in a sealed box. Some songs give too much bass, others I'm looking for more. In the end I'd rather have more than less. I have a ton of room under my helm - enough I believe that I could build a bigger sealed box and have both subs in it - most likely one facing up, the other facing back. For example if each sub suggests .75 cu ft for a sealed box then would I be looking at building a 1.5cu ft box? Running them parallel for a 2ohm load I'm confident I have plenty of power off my sub amp still. Just wondering if it would be worth it I guess.
    Oct 2010
    Lake Wylie NC Area
    Simply building a ported enclosure for the current sub would greatly increase its output without the need for increased amplification. Just retune.
