Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Quote Originally Posted by DOCDRS View Post
    with the pins loose prying on the motor mount as you tap the trunnion it did not move? something does not sound right
    pins loose, prying on the motor mount and tapping the trunnions as well as the pry bar...
  2. #22
    Jul 2002
    London Ontario Canada
    mine was stubborn but it did move once I started tapping the trunnions. Maybe some pb blaster or similar as it must be rust frozen. I am assuming both port and starboard sides are loose when your doing this and that you could get neither to move. My hardest part was getting a good footing with the crowbar so I could put some serious pressure on the two. I couldnt get it to budge till I started tapping on the engine mount stud.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
