Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Arkansas
    Default Switch to dripless
    Who has made the switch from the old style packing to the dripless?
    I am going to have to repack my older style over the winter and curious if I should just switch to dripless and whether or not its worth the cost.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Tooele UT....
    I have heard to go with some teflon coated seals that don't need changing near as often as the standard wax cord. look at that route. you can do a lot of changeouts for the cost of the dripless.
    Apr 2008
    California
    Your right on that one, but then I have absolutely no water in my bilge either nor the hassle of changing out the packing. Gotta way the pro and cons.
    Tooele UT....
    water in the bilge is no biggie for me. that's what you have a bilge for seems that water gets in there from ballast, wet peeps on the rear hatch.. etc....
    dealer here quoted me $75 for packing cord irregardless of whether they supply the basic wax cord or I provide the teflon stuff which is fairly cheap.. I would think you could do that change 4 times for the cost of a dripless setup. if you only do the teflon cord every 3 years, you are now beyond where most would keep the boat..
    either way, a personal preference..
    Apr 2008
    California
    The PSS dripless runs under $200 and the OJ around $160, not as bad as you'd think it is.
    How often to the dripless seals need to be replaced if at all?
    Arkansas
    I'm pretty sure the dealer qouted me even less than 160 (not including labor).
    That was my reasoning for considering the switch.
    Sent from my DROIDX using Tapatalk
    2016 Moomba Mojo
    Jul 2002
    London Ontario Canada
    They should last 350-500+ hours depending on alignment and cool water housing cooling. If you can align your shaft you can do the conversion. It sure is nice to have a dry and clean bilge imo.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    May 2003
    Orlando, FL
    I have been using dripless for 2 years now and like it. No worries about repacking or anything. I get water in the bilge from everything else. It is just nice to not have to worry about repacking it anymore.
    Gordon White
    2003 Moomba Outback
    Tooele UT....
    hmm..
    dealer here was tossing around $400 numbers right after I bought the boat. that's a much more manageable price and def. is worth a look..
    i'm with inliner tho as it seems there's always water getting in there from something. noobs driving the boat during surfing seems to be the most common
