Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. #21
    Apr 2008
    California
    I've mounted plenty there before np. There's a piece of 3/4" plywood glassed into the structure for rigidity the best I can tell. When i re-did mine I made and carpeted a panel that fits that space and mounted it to the wall 1/2" off. I then mounted all my goodies to the panel, minimized drilling there and worked well.
  2. #22
    Arkansas
    Yep, echo what they said. It can be done.
    My first year I mounted 2 amps directly to the wall. This past year we (Dusty and I, mostly Dusty) rigged up a panel like Razz and then we mounted it to the wall.
    My setup
    Dustys newest ... it seems to be able to handle the weight cause he has alot on it now
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  3. #23
    Nov 2003
    Land O Lakes, Florida
    KG or Dusty, in looking at your setups I dont see fuses, am I missing it or are you amps not fused?
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  4. #24
    Nov 2003
    You of all people should not be afraid to DRILL!
    Me? or David?
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  5. #25
    Feb 2010
    Canton, Ga / Lake Lanier
    My setup
    What series JL amps are those?
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  6. #26
    Jan 2010
    North Texas
    Look next to the 800.4 on my main rack. To the left is a fused distro block. Each amp is independently fused.
    2006 Supra 20 - Sold
    2015 Supra SE450
  7. #27
    Nov 2003
    Quote Originally Posted by dusty2221 View Post
    Guess I didnt know those where fused also, where do I get one?
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  8. #28
    Jan 2010
    North Texas
    Here ya go, I absolutely love it. Don't forget the fuses to go along with it! This little item will def. help the "clean-ness" of your install!
    http://www.sonicelectronix.com/item_...TPFDB-4PG.html
    2015 Supra SE450
  9. #29
    If you already have non-fused distro block(s) you may consider going with circuit breakers instead. See Raz's example. I went that route. If by chance it ever pops there's no disassembly require to get a new fuse put in there. (moving gear, people, etc) Just reset and go.
  10. #30
    Me? or David?
    That was directed at the guy who should not be afraid to drill as he works HERE:
