Results 1 to 3 of 3
Thread: Hydrolic Lock?
12-03-2011, 05:59 PM #1
Hydrolic Lock?
Didnt have any fog spray on hand, so I used marvals mystery oil and sprayed quite a bit 7-10 second spray in my cylinders for winter. Do I need to worry about start up and hydrolic lock? Or do you think im safe? Just dont know how much it can take? Jet
89' Comp Resto:
http://supraboats.com/bbs/showthread.php?t=8193
Riding and Mod pic's:
http://www.supraboats.com/bbs/album.php?albumid=86
89' Supra/Custom Tower & Interior/Swivel Racks
4 Blade-14X14/1600 lbs Ballast
Roswell Bar/Led's/Krypt 6.5 HLCD's/Krypt 4200 Eq
JL-PPI Amps 1750 Watts/Kicker Interiors/L7 Kicker Sub
12-03-2011, 06:57 PM #2Junior Member
- Oct 2011
- Cordele ga
- 8
you should be fine some of it will leak by rings
2007 möbius lsv
12-03-2011, 09:17 PM #3
7-10 seconds is quite a bit.....only need 2-3 secs. After you spray you should bump the motor over to distribute the oil other wise its just in the one place. you can pull the lanyard or put throttle in flooded engine mode and turn over with the plugs out. generally even with the plugs in the force of the starter turning is not enough to bend a rod or cause damage.
09 21v LAUNCH
99 Outback LS. Sold
Doug
