Results 11 to 20 of 20
12-01-2011, 04:43 PM #11-Ryan
twitter.com/WakeVideos
2000 Mobius V
12-01-2011, 08:58 PM #12
Good info, thanks for calling Moomba. I'd like to see some pics after you install the new brackets and see what changes they made.
12-02-2011, 11:00 AM #13
that pretty much settles it then, i'll be plting ours as soon as I'm up and around again. I was wanting to take the sundeck/engine cover off anyways and fix a couple of loose hinge screws in it too...
'00 Moomba Kamberra
'99 BMW 528it
12-02-2011, 02:01 PM #14Al
12-03-2011, 01:41 PM #15
Price on brackets and mounts...
The price I mentioned on previous post for the brackets and mounts should have said each. Sorry
Rick
2002 Moomba Mobius V
12-03-2011, 01:58 PM #16
Edit to post
The price I mentioned on previous post for the brackets and mounts should have said each. This was the price before discount. Sorry...So like $172.00 plus tax and shipping. Talked to dealer today in houston about repairs for the spring since my boat is in storage already. Said it takes about a 5 to 6 hours to actually complete repair.
Cab13367, Not sure about accessing below rear locker. He said they remove the carpet and the put it back after like they were never there. When I get it completed in the spring I can post pics. 1-800-847-9247 is Rinkers boat World number if want to call Scott for more details.Rick
12-05-2011, 01:53 PM #17
Here is a picture of what I did. I didn't undo the carpet on the other side of the transom to show the backing plate, I can do it this spring if you'd like to see it.
IMG_1244.jpg2002 Outback LSV
12-05-2011, 03:25 PM #18
I contacted the dealer where I bought my boat (Romoboco in Pueblo, CO) and this was the response:
"Yes the floor has to be cut out, foam removed, new plates installed. The newest method SC is using is to use an access plate instead of reglassing the floor. Depending on which mounting bolts are loose we have also pulled the lower bolts, filled w/ epoxy, re-installed bigger self tapping bolts and then drilled and installed additional self tapers above those. Approx time on self tap, 4 hours- approx time on new plates 12 hours."
I then asked if this is covered under the lifetime structural warranty and this is the response:
"It depends on the situation if it is covered under warranty. Typically, if the bracket on the boat is usable it will not be covered. By the way, gel coat cracking is not covered after 1 year, however if the platform is going to fall off it will be covered under the structural warranty."
I have some slight spider cracking at the bracket mounting holes. I have not checked to see if the lower bracket screws are stripped but my brackets seem to be firmly attached. I will check it sometime this winter.
AlAl
12-07-2011, 09:24 PM #19
Al, The dealer I contacted said they tried using bigger screws, they had some come back with the same issue. Thats why they put the plates on all of them now. The platform will probably not ever fall off, so the structural warranty will never even be used..
I got the new brackets in the mail today...Looks like the new design will work with the allen screw to keep the platform from moving up and down as much. My concern is the the allen screw will wallow out the metal that it tightens too on the platform bracket. Guess I will find out in the spring....Rick
10-29-2017, 05:03 PM #20Junior Member
- Oct 2017
- 2
Having the same issue and looking to DIY over the winter. Does anyone have photos of the inside plates installed or links to photos and details of the backing plate fix on this?
