Results 1 to 6 of 6
Thread: Fuel Filter????
11-08-2011, 05:41 PM #1Senior Member
- Aug 2007
- Alpine, Utah
- 191
Fuel Filter????
Where the heck is it on an 07 LS direct drive? I can't find it anywhere. I even puled the small floor plate that is right behind the motor off and still I couldn't find it.
GarnGarn
2007 Mobius LS (Direct Drive)
11-08-2011, 08:59 PM #2
If similar to the '07 Outback DD, the fuel filter is affixed to the stern just above the fuel tank. You access it through the rear storage area. - Deerfield
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
11-08-2011, 09:53 PM #3Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
Yes like Deerfield says ,at least on the Outback you have to remove a panel or two in the rear ski locker to get to the fuel filter.The resevoir for the hydraulic wakeplate is behind a panel back there as well.
07 Outback DD
11-09-2011, 11:27 AM #4Senior Member
- Aug 2007
- Alpine, Utah
- 191
Thanks guys. I'll look there.
GarnGarn
11-09-2011, 12:29 PM #5
On my 03 LS the filter is on the inside of the starboard stringer right under the blower.I couldn't find it right away because the blower hides it.I removed the blower(one screw) to change the filter.
jy
11-10-2011, 12:52 PM #6Senior Member
- Aug 2007
- Alpine, Utah
- 191
I"ll check there as well. Thank you.
Garn
