Results 1 to 7 of 7
    Sep 2010
    B.C. Canada
    Default Fall projects including midship drain plug
    Just catching up on a few things I wanted to get done now that the season is over.
    I added a midship drainplug as mentioned in another thread. It was fairly easy, just need to be careful as there is only 3/4" airspace between the hull and fuel tank. I used a standard garboard drain with a 1/2" plug (same as in the transom drain) and #8 x 5/8" flathead SS screws. A Forsener 1" drillbit and a bit of masssaging with a die grinder made for a perfect fit. A It fit perfectly in the recess between the fins and I doubt very much that it will cause any drag at all as the base of the fins are much taller that the garboard flange. Nice to be able to drain the midship bilge now especially before long term storage.
    I also got tired of the cheesy plastic cover on the stern where the rub rail ends so I made one out of a piece of SS pipe and polished it.
    Then there was the concern over losing the swim grid if it broke off, so I added some safety cables so at least if it does, it will still be attached to the boat.
    Also added pop-up cleats, but that was awhile ago.
    Cheers,
    BB
    2005 Moomba Mobius LSV
    Jan 2010
    North Texas
    Looking good, nice work on the drain.
    Sent from Galaxy S2 using Tapatalk.
    2006 Supra 20 - Sold
    2015 Supra SE450
    Drain looks great. Must admit that you're braver than me with a drill.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Des Moines, IA
    Very nice upgrades!
    Nov 2003
    Land O Lakes, Florida
    way braver than me too, drilling that center drain.
    keep it up and keep the pics coming
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Jun 2011
    I like the pop up cleats, thinking of adding a few to mine. Where did you order yours?
    Brandon
    2000 Moomba Outback LS
    2001 American Skier LazAir Edition
    1991 Ski Tastic Inboard
    Sep 2010
    B.C. Canada
    Quote Originally Posted by keehr22 View Post
    They're made by Sea dog and I got them from Amazon.
    I made my own backing plates out of 1/8" x 2" SS flat bar.
    Cheers
    BB
