Results 1 to 9 of 9
Thread: Speedometer not working
05-11-2005, 03:32 PM #1Senior Member
- Aug 2002
- Bismarck, NorthDakota
- 579
Where do you start? is it the wheel or the gauge.
What does it cost to replace the paddle wheel and cable?
2001MobiusBruce Fuerstenberg
05-11-2005, 04:18 PM #2Member
- Apr 2005
- 48
Replying to Topic 'Speedometer not working'
Is it just one speedo not working? The paddlewheel is about $15. That is for just the little paddlewheel and the shaft that it rides on. That will fix it some of the time.
05-11-2005, 04:19 PM #3Senior Member
- Aug 2002
- 579
Just the one speedo. I think it is more like the sensor and wheel that is bad
Bruce Fuerstenberg
05-11-2005, 04:25 PM #4Member
- Apr 2005
- 48
Well you can take the wheel out the one that is working and put it in the one that is not and see if that fixes the problem. Then you should know if it is the paddlewheel itself. If you tow your boat long distances and don't put tape over the paddlewheel it can burn it out from spinning with no water to lubricate it.
05-11-2005, 07:37 PM #5Senior Member
- Jul 2003
- 340
Correct me if I'm wrong, but I think there is only one sensor and paddlewheel in the hull of the boat that runs both speedos. If that's the case, it sounds like a problem with a loose wire or something wrong with just the one speedo.
05-11-2005, 08:51 PM #6Senior Member
- Aug 2002
- 579
My boat has two at the rear of the boat.
Bruce Fuerstenberg
05-11-2005, 10:40 PM #7Guest
I believe they made the switch in 2002. Thats when they went to the single midship paddlewheel. Be sure to let us know what you find out.
05-11-2005, 10:47 PM #8Member
- Apr 2005
- 48
I believe they made the switch in 2002. Thats when they went to the single midship paddlewheel. Be sure to let us know what you come up with Bruce.
05-12-2005, 06:00 PM #9Senior Member
- Jul 2003
- 340
That would explain it, mine's an '03. Thanks.
Speedometer issue
By weirdo0521 in forum General ChatReplies: 0Last Post: 05-31-2006, 12:07 PM -
speedometer
By alex in forum Boat OwnersReplies: 4Last Post: 05-02-2006, 01:45 PM -
Speedometer dead
By Father of 5 in forum Service & RepairReplies: 3Last Post: 09-07-2005, 11:16 PM -
speedometer
By tpfisher in forum Service & RepairReplies: 0Last Post: 06-20-2004, 12:05 AM -
Speedometer calibration
By sloppy in forum Boat OwnersReplies: 2Last Post: 08-02-2002, 08:17 PM
