Results 1 to 1 of 1
    Jul 2002
    London Ontario Canada
    Default Oil Change Video
    Here is my oil change video. I had to use a fram ph5 as for some reason I bought the wrong mobil filter...needed a M1-302. I use an oversize filter as i see no reason not to and why wouldn't you. I prefill my filter with oil about 4 times as the paper absorbs a lot of oil. Make sure the rubber gasket comes off with the old filter and coat the new gasket with some oil to make for easier removal. I use shell rotella 15w40 oil.
    I also over fill the dipstick tube slightly as the oil filter will absorb more oil. The oversized filter will hold almost a litre/quart of oil. More protection for your engine.
    http://www.youtube.com/watch?v=A9puJe0Hfe8
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
