Results 1 to 10 of 16
Thread: Can't get oil drain nut off
10-09-2011, 01:43 PM #1Junior Member
- Oct 2011
- Cloquet, MN
- 15
I changed my oil, but in the process I stripped the crap out of the connector on the end of the drain hose. The nut would not come off and I had to use channel lock pliers because it just spun. I added a little to much oil and need to drain a little out, but now I can't get the nut off. Not sure I want to strip it more but I need to get some oil out.
Help
10-09-2011, 02:30 PM #2
You have two choices as I see it. 1) replace the drain hose assembly or 2) Buy yourself an oil extractor and remove the excess oil through the dipstick and use it for all future oil changes.
pela.jpg2007 Mobius LSV
10-09-2011, 05:13 PM #3
I agree with Razz. Get an oil extractor to get the oil down to the right level and for future oil changes. With respect to the damaged brass fitting, maybe cut the end of the hose and replace with a new brass fitting and cap from auto parts or home supply center?DSC_0153.jpgDSC_0149.jpgDSC_0148.jpg
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
10-09-2011, 06:08 PM #4Junior Member
- Oct 2011
- Cloquet, MN
- 15
That's what I thought I would need to do. I'll start with the extractor, but I would still like to replace the brass cap if possible. I assume I need to wait unti the next oil change to cut the hose? Not quite sure if I am capable of putting a new cap on that would hold?
Thanks for the suggestions,
10-09-2011, 08:16 PM #5
Young - These brass hose fittings from Lowes are what I have in mind. You will need to make sure that the extractor hose will fit through the diameter of the barbed fitting. Maybe just take a drive to the home supply center with the end piece cut from the hose to se what is the best solution. - Deerfield
http://images.lowes.com/product/conv...43071612lg.jpg
http://images.lowes.com/product/conv...43071957xl.jpg2007 Outback - SOLD June 2016
2012 RAM Crew Cab
Stuart
10-09-2011, 09:19 PM #6Junior Member
- Oct 2011
- Cloquet, MN
- 15
Deerfield I like your idea. Do you think the one that goes inside the hose will hold? Is there pressure on the oil drain hose that might push that loose?
Appreciate the help,
Young2006 Outback V
310 Carb
10-09-2011, 09:22 PM #7Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
10-10-2011, 08:13 AM #8
There is no pressure on the drain hose at all. Even if the ingine was running and you opened it all that happens is the oil would drain. They pressure is after the oil pan pump. The extrators goes down the Dip stick tube not the oil drain tube. just but a new plug and forget about it. Buy the extractor Razzman posted, Al Cab let me borrow his last rummer and i bought it after 1 use. It works great.
It drains the trans, and then i drain my engine oil. I also use it to drain small engines oil, drain the oil from my drive axles on my 1 ton truck to service them. Its an awesome pump for 50 bucks. Already paid for its self the first time i used it.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
10-10-2011, 08:48 AM #9
I have that same pump and it is the bomb... worth the money and not having to ever fight that drain hose again.
as far as sealing up the drain line, cut the end off, put a stainless bolt in it that fits and use a stainless hose clamp. if you need to get at it again, undo the hose clamp and pull the bolt out.
good luck..'06 Supra Launch 20SSV-gone but never forgotten
10-10-2011, 06:10 PM #10
You guys use the extractor to pull oil out the dipstick? I've been using the drain hose with the extractor. Guess there's two ways to skin a cat eh?
2015 Supra SC400
08 LSV - Sold
Go big, or go home.
