Results 1 to 10 of 22
Thread: Another winterizing question
10-06-2011, 07:24 PM #1
Ok so I took my boat up to the dealership for some warranty work and a snap tarp cover...anyhow while it was there I told them to have it winterized..well I talked to the manager and asked how much the winterizing was and he said he didn't exactly know but around 400 bucks...no oil change just a winterizing..well I paid 130.00 here in medicine hat last year. To a indmar approved dealer...is there anyone in my area that has any ideas of what it should cost at "the moomba supra dealer"?????
2010 möbius ls "you ain't fallin you ain't learning"
10-06-2011, 08:08 PM #2
Generaly a winterization is around 200 all it is on the newer modles is changing the oil, draining the block and heater core. They generaly dont Fog any FI boats due to it causing FI issues.
If i was you and you dont want to do the oil change your self then winterize it yourself. There is some really good write ups with pics and its a really simple process. Even easier for you since your a direct drive. Pull both block plugs, let them drain. Then pull the hoses for the heater core and blow air threw them to drain the water. open the impeller housing and remove your impeller store in zip lock with some vasaline. Done.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
10-06-2011, 08:52 PM #3Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
When i got my boat from Mobius a few years back ,Winterize was about 280.00 without oil change. As mentioned above its really not that hard and you can do the oil change at the same time and save even more cash. Took me aprox 2 hrs with oil change and tranny fliud. Taking my time.
07 Outback DD
10-06-2011, 08:55 PM #4Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
All boats should be 'fogged'. While it was standard to fog the engine through the carb while running, EFI should not have that. The plugs should be pulled and each cylinder fogged. That is really the proper way it always should have been done. If you dealer (or whoever) isn't doing that, look elsewhere or do it yourself. When humidity gets on those nice shiny cylinder walls of open valved chambers, it only takes the orange stuff a few hours to set on. A little surface rust will wipe a set of rings on the first start up of the new year.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
10-06-2011, 09:41 PM #5
I know it's easy to do but I went for a last ride Friday night and had to have it to the dealer 3hrs away the following morning at 11am they were storing it outside and it has been getting cold out and they won't have the boat ready till the end of October I thought it would be a good idea to have it winterized.. I just didn't have the time..I will be pissed if they charge me more than 300
10-06-2011, 11:05 PM #6
I would ask for a break down of exactly what they did. It may make you feel better or worse. Then , at least, you have a record of what they did and you can decide to do or not next year. I agree with Max totally...the only way to properly winterize is to fog thru the spark plug just don't blow the tube into the cylinder, and to do an oil change then run the engine so all the internals are coated with fresh virgin, non contaminated oil.
If your dealer is 3 hours away , thats 6 hours there and back , it'll take you 2 hours at most to do it all your self the first time. If they do say they checked the alignment, I would ask what exactly the tolerance was.Last edited by DOCDRS; 10-06-2011 at 11:07 PM.
09 21v LAUNCH
99 Outback LS. Sold
Doug
10-06-2011, 11:25 PM #7
I can agree with you to a point.
Our Moomba dealer doesnt fogg the FI engines not because they dont want to but because they were told not to by eigher SC or Idmar. I dont recall but it became an issue and so they stoped. I dont think they care if tis done or not due to they will do what ever you ask but they stoped because people above them told them to stop.
I also understand the idea of keeping rust off the cylinder walls but i have had many cars that sat for years and fired right up with some fresh fuel and ran fine. Also i have pulled many engines apart right out of a junk yard when i was rebuilding them for a living and the only time i ever saw rusted cylinders was when there was a blown head gasket or no carb on the intake.
Not to argue at all by all means Fogg your engine if you like, i just dont do it because my dealer said its best to not do it. Now my boat stays in my garage which is heated and doesnt see excessive humidity so i also dont have to worry about that.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
10-08-2011, 09:05 PM #8Junior Member
- May 2010
- Airdrie AB
- 15
I had my '09 lsv winterized last year by likely the same dealer yu are going to. (Martin Equip) . I had the oil Changed, V-drive oil changed and the whole thing winterized. Cost me $400.00. Btw the heater core froze. Anyways, I winertized it myself this year,following the cab13367 sticky on winterization. The only deviation i did was to run anti-freeze thru everything before draining. I wanted to be extra cautious. Whole process took about 1 hour. Money well saved!!
10-08-2011, 09:55 PM #9Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Any advice I give is only based on either my experience, or what the manufacturer states to be done. Living in the S.E., we have a humidity issue, which causes rust. While living in CA, I learned about "dry air". Living in Iraq, I learned about intensive heat. Anyway, some areas of the country don't need to do things that other do. In fact, there is no need for me to winterized at all where I live.
A lot of car and boat makers stopped recommending fogging with the advent of EFI due to an issue with instruction on the cans telling people to fog a running engine. This can and has ruined mass air flow sensors and o2 sensors, plus a properly running EFI car engine will not get 'choked out' with a standard can of fogging oil.
Like has been said before, winterizing isn't hard. If you have to drive a long distance to a dealer, it probably make sense to do it yourself. However, if you miss a step and freeze an engine or something, there isn't much recourse and you can only blame yourself and the internet forums that convinced you to "do it yourself".
Good luck.1997 MasterCraft 205
2008 Moomba Outback
10-08-2011, 10:38 PM #102007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
