    Apr 2011
    Default Anyone know the stock rating on GIII intake pump??
    Hey guys, I have an O3 LSV and I would like to know what the stock rating on the ballast intake pump. I have removed it to double it up on the thru hull fittin as suggested on the forum. I can't find the rating anywhere. Thanks.
    If its the rule hi flow. It should be 1200 gph.
    Yup, if it's the same one it's called the "Rule 2000" but it's rating is 1200 gph. Al posted a list with all the specs once upon a time.
    Newty did a test on this and it only helps fill times with mutiple bags at once with the 3/4 hose configuration and stock sprinkler valves.
