Results 11 to 16 of 16
Thread: paging Dr. Brian
05-09-2005, 11:55 PM #11Brian Raymond Guest
Replying to Topic 'paging Dr. Brian'
It should take no more than 30 secs. to prime, any longer can build up heat in the pump (due to air) and lead to a quicker demise. The trim fluid is Dexron III trans. fluid, available at any auto store. Remember, when checking fluid level to have the plat in the full up pos. This will have all the fluid from the lines in the sump for a proper reading. If it is overfilled, it will leak out and make a *#&% mess. Brian Raymond
05-09-2005, 11:59 PM #12
Brian thanks again and I'll keep you posted on the fuel pump. that'll teach me to look and not touch.
chrisCS
05-11-2005, 02:59 PM #13
A quick follow up.a very bad form of vapor lock .winter blend gas first 80+ degree day and carb. old schoolers will remember this. Dr Brians last ditch idea paid off since I had pretty much beaten him to all other ideas.I was finally able to reprime the pump,line and get fuel to the carb and back in business. thanks Dr.B.
seanpatsdad, i would bet they either tapped on,blew out or found debris in your antisiphon and didnt remove the ball. I had a chance to get up close and personel with mine thru this and I think you would destroy the fitting if you tried to punch it out let alone the tank.
chrisCS
05-11-2005, 05:40 PM #14Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
I'm with you the ball is still there, just knocked out e.g. not jammed.
SD2Naked red and white 2005 Moomba LSV
05-11-2005, 06:52 PM #15Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
It was not mine, it was Buttafewcoe.Glad to hear itworked out for you.
John
05-12-2005, 04:01 PM #16Senior Member
- Jul 2003
- Carson City, NV
- 157
Chris (BLKOUTLS),
I've been following this conversation and wondered what exactly you ended up having to do to get the pump primed. You referred to Brian's last idea but was it jumping the pump switch that finally solved it? If so, was it a two or three wire switch on yours? Thanks. These things are very educational for me.
Brian Raymond
By WakeMe in forum General ChatReplies: 2Last Post: 03-31-2006, 11:11 PM -
Brian Raymond
By Brian Raymond in forum Boat OwnersReplies: 8Last Post: 10-23-2005, 10:30 PM -
Brian Raymond
By Lpfeil in forum General ChatReplies: 9Last Post: 01-31-2004, 02:36 AM -
Brian Raymond?
By Bfrank in forum Service & RepairReplies: 8Last Post: 01-06-2004, 10:21 PM -
Brian Raymond
By dburroug in forum Service & RepairReplies: 1Last Post: 10-11-2003, 11:15 PM
